# Wifi board issue
**URL:** <https://forums.openmv.io/t/wifi-board-issue/210>\
**Category:** OpenMV Boards\
**Created:** [February 28, 2017, 3:04pm UTC](https://forums.openmv.io/t/wifi-board-issue/210 "2017-02-28T15:04:16Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![schildroth](https://avatars.discourse-cdn.com/v4/letter/s/f17d59/32.png) [@schildroth](https://forums.openmv.io/u/schildroth)\
**Post date:** [February 28, 2017, 3:04pm UTC](https://forums.openmv.io/t/wifi-board-issue/210/1 "2017-02-28T15:04:16Z")
</div>
I’m trying to setup wifi board using the mjpeg\_streamer\_1.py program.
Appears to connect fine, but then I immediately get a ‘-6’ error. What is that error?
MicroPython v1.8-4345-g3a2670b on 2016-11-03; OPENMV2 with STM32F427
> > > Trying to connect… (may take a while)…
> > > [-58, 2, ‘ASUS’, ‘f8:f0:05:f7:5a:8b’, ‘192.168.1.93’]
> > > Waiting for connections…
> > > 6
> > > -6
> > > socket error: -6
> > > socket error: -6
**Post date:** [February 28, 2017, 3:22pm UTC](https://forums.openmv.io/t/wifi-board-issue/210/2 "2017-02-28T15:22:18Z")
</div>
Hi, that was an error with an old firmware version and such. Please update the IDE and your firmware version. In particular, you need to change a line in the streamer script.
> <https://github.com/openmv/openmv/commit/e8dcb2863d03cbf376dbe1140f2923168cff8062#diff-c300b659ff008585d0e1e1b32b353c4c>
**Post date:** [February 28, 2017, 3:48pm UTC](https://forums.openmv.io/t/wifi-board-issue/210/3 "2017-02-28T15:48:07Z")
</div>
That was it! Thank you for the quick response.
Will the M7 improve the fps? I’m only getting about 2.5fps when I go QVGA/RGB565.
**Post date:** [February 28, 2017, 4:24pm UTC](https://forums.openmv.io/t/wifi-board-issue/210/4 "2017-02-28T16:24:16Z")
</div>
Somewhat. But, you should be able to get a lot higher than 2.5 FPS with the M4. So… this means the WiFi is just a bottleneck. Not sure how to test what the problem is.
