Mmm, that would be an MicroPython Hal change. Let’s see the API:
It looks like you have everything here:
STATIC mp_obj_t file_obj_make_new(const mp_obj_type_t *type, size_t n_args, size_t n_kw, const mp_obj_t *args) {
mp_arg_val_t arg_vals[FILE_OPEN_NUM_ARGS];
mp_arg_parse_all_kw_array(n_args, n_kw, args, FILE_OPEN_NUM_ARGS, file_open_args, arg_vals);
return file_open(NULL, type, arg_vals);
// TODO gc hook to close the file if not already closed
STATIC const mp_rom_map_elem_t rawfile_locals_dict_table[] = {
{ MP_ROM_QSTR(MP_QSTR_read), MP_ROM_PTR(&mp_stream_read_obj) },
{ MP_ROM_QSTR(MP_QSTR_readinto), MP_ROM_PTR(&mp_stream_readinto_obj) },
{ MP_ROM_QSTR(MP_QSTR_readline), MP_ROM_PTR(&mp_stream_unbuffered_readline_obj) },
{ MP_ROM_QSTR(MP_QSTR_readlines), MP_ROM_PTR(&mp_stream_unbuffered_readlines_obj) },
{ MP_ROM_QSTR(MP_QSTR_write), MP_ROM_PTR(&mp_stream_write_obj) },
{ MP_ROM_QSTR(MP_QSTR_flush), MP_ROM_PTR(&mp_stream_flush_obj) },
{ MP_ROM_QSTR(MP_QSTR_close), MP_ROM_PTR(&file_obj_close_obj) },
{ MP_ROM_QSTR(MP_QSTR_seek), MP_ROM_PTR(&mp_stream_seek_obj) },
{ MP_ROM_QSTR(MP_QSTR_tell), MP_ROM_PTR(&mp_stream_tell_obj) },
{ MP_ROM_QSTR(MP_QSTR___del__), MP_ROM_PTR(&file_obj_close_obj) },
{ MP_ROM_QSTR(MP_QSTR___enter__), MP_ROM_PTR(&mp_identity_obj) },
{ MP_ROM_QSTR(MP_QSTR___exit__), MP_ROM_PTR(&file_obj___exit___obj) },
And most of those methods are defined here:
* This file is part of the MicroPython project, http://micropython.org/
* The MIT License (MIT)
* Copyright (c) 2013, 2014 Damien P. George
* Copyright (c) 2014 Paul Sokolovsky
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
This file has been truncated. show original
So, I’d use the readline() method to read one line in a loop. The readlines() method will return all lines in the file but that will cause you to likely run out of RAM given the file size.
Question, is the file a binary file? If so, then readAll() may still work on it. What mode did you open the file in?
