# Use pin P6 with the Wifi Shield
**URL:** <https://forums.openmv.io/t/use-pin-p6-with-the-wifi-shield/2138>\
**Category:** OpenMV Boards\
**Created:** [January 22, 2021, 11:29am UTC](https://forums.openmv.io/t/use-pin-p6-with-the-wifi-shield/2138 "2021-01-22T11:29:55Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![AlfonsoAIT](https://avatars.discourse-cdn.com/v4/letter/a/858c86/32.png) [@AlfonsoAIT](https://forums.openmv.io/u/AlfonsoAIT)\
**Post date:** [January 22, 2021, 11:29am UTC](https://forums.openmv.io/t/use-pin-p6-with-the-wifi-shield/2138/1 "2021-01-22T11:29:55Z")
</div>
In my application I need to stream video with the Wifi Shield and, at the same time, use the analog output to send the result of the vision task. The analog output goes through the pin P6, but this pin is used by the Wifi Shield.
Is there any way to overcome this?
Thanks!
**Post date:** [January 22, 2021, 3:17pm UTC](https://forums.openmv.io/t/use-pin-p6-with-the-wifi-shield/2138/2 "2021-01-22T15:17:52Z")
</div>
No, it must be used for the wifi module…
**Post date:** [January 22, 2021, 5:41pm UTC](https://forums.openmv.io/t/use-pin-p6-with-the-wifi-shield/2138/3 "2021-01-22T17:41:36Z")
</div>
Use an external microcontroller with a DAC, or PWM over an I/O pin that’s free with an RC filter.
