# Unstable exposure time (fixed exposure time)
**URL:** <https://forums.openmv.io/t/unstable-exposure-time-fixed-exposure-time/1932>\
**Category:** OpenMV Boards\
**Created:** [September 14, 2020, 12:48pm UTC](https://forums.openmv.io/t/unstable-exposure-time-fixed-exposure-time/1932 "2020-09-14T12:48:06Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![mos.pp](https://avatars.discourse-cdn.com/v4/letter/m/4491bb/32.png) [@mos.pp](https://forums.openmv.io/u/mos.pp)\
**Post date:** [September 14, 2020, 12:48pm UTC](https://forums.openmv.io/t/unstable-exposure-time-fixed-exposure-time/1932/1 "2020-09-14T12:48:06Z")
</div>
Hi there,
I am using H7 with Global Shutter Camera.
I am having a problem with unstable exposure time when there is time-consuming process before sensor.snapshot().
This problem can be reproduced when using below example modified from **sensor\_exposure\_control.py**
I believe that this can be observed in the other examples with fixed exposure time and time-consuming algorithms.
```python
    t0 = pyb.millis()
    while (pyb.millis() - t0) < 500:
        pyb.delay(10) # Some time-consuming process
    sensor.skip_frames(1) # THIS MUST BE HERE. Otherwise, sensor.snapshot() will have unstable exposure.
    t_snapshot = pyb.millis()
    print('t_snapshot()=',pyb.millis()-t_snapshot) # Note: OpenMV Cam runs about half as fast when connected
    while (pyb.millis() - t_snapshot) < 500:
For example, I used fixed exposure as 20000us (20ms).
BEFORE FIX (no sensor.skip\_frames(1))
```python
t_snapshot()= 20
t_snapshot()= 13
t_snapshot()= 21
t_snapshot()= 12
t_snapshot()= 21
AFTER FIX (with sensor.skip\_frames(1) just before sensor.snapshot())
```python
t_snapshot()= 18
t_snapshot()= 18
t_snapshot()= 18
t_snapshot()= 18
t_snapshot()= 18
t_snapshot()= 18
t_snapshot()= 18
t_snapshot()= 18
t_snapshot()= 18
t_snapshot()= 18
t_snapshot()= 18
When I check with oscilloscope, when t\_snapshot is 13, t\_snapshot happens in the middle of the VSYNC pulse)
For now, I can include sensor.skip\_frames() to produce a consistent exposure but it will always waste exposure time every loop (20ms in above case).
Would it be a bug that can be fixed in the firmware?
Thank you and I look forward to your reply,
Kind regards,
Phil
**Post date:** [September 14, 2020, 2:42pm UTC](https://forums.openmv.io/t/unstable-exposure-time-fixed-exposure-time/1932/2 "2020-09-14T14:42:01Z")
</div>
The time it takes snapshot to return has nothing to do with the camera exposure. This isn’t a bug…
Snapshot just grabs a frame from the camera sensor. The camera controls the exposure internally, what you are seeing is the affect of how our frame grabber architecture grabs the next frame coming out the camera.
To note. The camera generated frame asynchronously, snapshot just waits and grabs the next value one. Each frame has the same exposure.
