# Ulab library
**URL:** <https://forums.openmv.io/t/ulab-library/1468>\
**Category:** OpenMV Boards\
**Created:** [November 7, 2019, 10:45am UTC](https://forums.openmv.io/t/ulab-library/1468 "2019-11-07T10:45:46Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![Melan](https://avatars.discourse-cdn.com/v4/letter/m/6a8cbe/32.png) [@Melan](https://forums.openmv.io/u/Melan)\
**Post date:** [November 7, 2019, 10:45am UTC](https://forums.openmv.io/t/ulab-library/1468/1 "2019-11-07T10:45:46Z")
</div>
How can i add ulab library to openmv camera?
**Post date:** [November 7, 2019, 12:17pm UTC](https://forums.openmv.io/t/ulab-library/1468/2 "2019-11-07T12:17:37Z")
</div>
ulab has been added in the latest firmware, just import ulab.
**Post date:** [November 7, 2019, 12:29pm UTC](https://forums.openmv.io/t/ulab-library/1468/3 "2019-11-07T12:29:15Z")
</div>
I cant, there is no module named ulab
**Post date:** [November 7, 2019, 4:27pm UTC](https://forums.openmv.io/t/ulab-library/1468/4 "2019-11-07T16:27:33Z")
</div>
You have to install the latest firmware from GitHub. The release to the IDE will happen in a bit.
**Post date:** [November 12, 2019, 7:33am UTC](https://forums.openmv.io/t/ulab-library/1468/5 "2019-11-12T07:33:14Z")
</div>
Thank you
**Post date:** [November 12, 2019, 7:46am UTC](https://forums.openmv.io/t/ulab-library/1468/6 "2019-11-12T07:46:17Z")
</div>
Hi, I tested the released firmware that is available with the IDE and it’s present. I just imported ulab in the import statement and it works. What board are you using.
**Post date:** [November 12, 2019, 7:48am UTC](https://forums.openmv.io/t/ulab-library/1468/7 "2019-11-12T07:48:30Z")
</div>
Thank you, i deleted and than installed it again and now its works
