The AE3 TOF don't work against a completely white wall
The AE3 TOF don’t work against a completely white wall it’s indicating 150-160 mm when it’s 300-500 mm
It seems to have trouble when there’s a lot of light.
Does it need sunglasses?
It’s work OK indors.
It’s a known limitation/issue with these ToF sensors, I don’t think there’s much we could do about that. You could try a lower framerate (longer integration), or 4x4 zones and see if it helps. If any controls do actually help, we can add the API for them.
Some ST partner does actually make them for these sensors. I’m not sure if it help with this particular issue, or if it will even fit in the space we have (with the case on):
https://www.st.com/en/partner-products-and-services/gilisymo-tof-cover-glass-family.html
There’s an app note here too, if you want to read more about it:
https://www.st.com/resource/en/application_note/an5939-guidelines-for-the-cover-glass-of-the-vl53l8-timeofflight-tof-multizone-sensor-family-stmicroelectronics.pdf
