# Serial port does not appear
**URL:** <https://forums.openmv.io/t/serial-port-does-not-appear/87>\
**Category:** OpenMV Boards\
**Created:** [June 15, 2016, 9:55pm UTC](https://forums.openmv.io/t/serial-port-does-not-appear/87 "2016-06-15T21:55:35Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![RonC](https://avatars.discourse-cdn.com/v4/letter/r/e19adc/32.png) [@RonC](https://forums.openmv.io/u/RonC)\
**Post date:** [June 15, 2016, 9:55pm UTC](https://forums.openmv.io/t/serial-port-does-not-appear/87/1 "2016-06-15T21:55:35Z")
</div>
Hi, I got my OpenMV today. Plugged it into my PC. Several LEDs flash and eventually the blue LED flashes continuously. The serial port does not appear. The IDE says to look at the preferences. No serial ports appear in the list. What am I missing?
Thanks, RonC
**Post date:** [June 15, 2016, 10:04pm UTC](https://forums.openmv.io/t/serial-port-does-not-appear/87/2 "2016-06-15T22:04:15Z")
</div>
> [@RonC](#):
> Thanks, RonC
Hi, I’ll need more info to help you, but so far your camera is good (Hardware wise). If you’re on Linux you need to install the udev rules (copy and paste dmesg and lsusb output if there’s a problem), if you’re on Windows you need to installed the openmv.inf driver (located on the camera itself, it should show as a mass storage device) if you’re on Mac we’re still working on OSx IDE.
**Post date:** [June 16, 2016, 12:16am UTC](https://forums.openmv.io/t/serial-port-does-not-appear/87/3 "2016-06-16T00:16:28Z")
</div>
For more info see the following:
> **[Home · openmv/openmv Wiki](https://github.com/openmv/openmv/wiki/)**
> OpenMV Camera Module. Contribute to openmv/openmv development by creating an account on GitHub.
**Post date:** [June 16, 2016, 4:36pm UTC](https://forums.openmv.io/t/serial-port-does-not-appear/87/4 "2016-06-16T16:36:12Z")
</div>
Ooops My USB cable is faulty, it supplies power, but nothing else. Sorry about that.
My OpenMV is now working (with a new USB cable) with the IDE.
Thanks for your quick reply.
**Author:** ![trevorb](https://avatars.discourse-cdn.com/v4/letter/t/a87d85/32.png) [@trevorb](https://forums.openmv.io/u/trevorb)\
**Post date:** [June 19, 2016, 10:53pm UTC](https://forums.openmv.io/t/serial-port-does-not-appear/87/5 "2016-06-19T22:53:50Z")
</div>
Great feedback, I just had the same issue faulty cable.
