Hey everyone,
I would send image over RPC to master, it done. how i can send image with other object, such as object rectangle same time?
My code on below
# This is called repeatedly by interface.stream_writer().
def stream_generator_cb():
# Capture snapshot
img.draw_string(10,10,"Aplikasi Pengenalan Wajah\nVersi 0.1",(255,0,0),1.5,x_spacing=2,mono_space=False)
# Find objects.
objects = img.find_features(face_cascade, threshold=0.75, scale_factor=1.25)
for r in objects:
print(r)
img.draw_rectangle(r,color=(255,0,0),thickness=2)
return img.compress(quality=90).bytearray()
Thanks for help
