Rpc master controller example not running
Hi Kwagyman;
So before I put it in the box for shipping I remembered that I hd had problem with a cracked SD card already and went to check it out. Turns that I just happened top check the properties on it and discovered that it mounted fine on the laptop showing 32GB. On the cam only 5Kb. that’s 5 thousand. Microscopic.
Replaced it in the laptop, scanned and fixed. Nothing. So this SD or your cam has a mounting problem. Windows is not complaining nor fouling.
What do you suggest?
Stimpy
BTW left some screenshots in that other post on USB problems if you want proof.
