Also If I want use a TFT screen with ili9341 Driver ?
Now is clear my misunderstanding , I was thinking that new firmware was fissing the problem rised originally by jacon with ili9341.
Anyway now I’ve solved using the byteswap function develope by jacob and the TFT 2,8 inc works ok .
This is the code
import sensor, image, time
from MP_ili9341 import ili9341
screen = ili9341()
screen.set_window(0,0,320,240)
#screen.load_image('bots16_320x240.bmp')
img_byte_array = sensor.snapshot().bytearray()
ili9341.byteswap(img_byte_array,len(img_byte_array))
screen.send_spi(img_byte_array, True)
and this the drive
from machine import Pin, SPI
import ustruct
class ili9341():
@micropython.asm_thumb
def byteswap(r0, r1): # bytearray, len(bytearray)
mov(r3, 1)
lsr(r1, r3) # divide len by 2
mov(r4, r0)
add(r4, 1) # dest address
label(LOOP)
ldrb(r5, [r0, 0])
ldrb(r6, [r4, 0])
strb(r6, [r0, 0])
strb(r5, [r4, 0])
add(r0, 2)
add(r4, 2)
sub(r1, 1)
bpl(LOOP)
def send_spi(self,data, is_data):
self.dc.value(is_data) #set data/command pin
self.cs.value(0)
self.hspi.write(data)
self.cs.value(1)
def __init__(self, cs='P3', dc='P9'):
self.hspi = SPI(2, baudrate=54000000)
self.cs = Pin(cs, Pin.OUT)
self.dc = Pin(dc, Pin.OUT)
for command, data in (
(0xef, b'\x03\x80\x02'),
(0xcf, b'\x00\xc1\x30'),
(0xed, b'\x64\x03\x12\x81'),
(0xe8, b'\x85\x00\x78'),
(0xcb, b'\x39\x2c\x00\x34\x02'),
(0xf7, b'\x20'),
(0xea, b'\x00\x00'),
(0xc0, b'\x23'), # Power Control 1, VRH[5:0]
(0xc1, b'\x10'), # Power Control 2, SAP[2:0], BT[3:0]
(0xc5, b'\x3e\x28'), # VCM Control 1
(0xc7, b'\x86'), # VCM Control 2
(0x36, b'\xF8'), # Memory Access Control
(0x3a, b'\x55'), # Pixel Format
(0xb1, b'\x00\x18'), # FRMCTR1
(0xb6, b'\x08\x82\x27'), # Display Function Control
(0xf2, b'\x00'), # 3Gamma Function Disable
(0x26, b'\x01'), # Gamma Curve Selected
(0xe0, b'\x0f\x31\x2b\x0c\x0e\x08\x4e\xf1\x37\x07\x10\x03\x0e\x09\x00'), # Set Gamma
(0xe1, b'\x00\x0e\x14\x03\x11\x07\x31\xc1\x48\x08\x0f\x0c\x31\x36\x0f')): # Set Gamma
self.send_spi(bytearray([command]), False)
self.send_spi(data, True)
self.send_spi(bytearray([0x11]), False)
#time.sleep(10)
self.send_spi(bytearray([0x29]), False)
def set_window(self, x0=0, y0=0, width=320, height=240):
x1=x0+width-1
y1=y0+height-1
self.send_spi(bytearray([0x2A]),False) # set Column addr command
self.send_spi(ustruct.pack(">HH", x0, x1), True) # x_end
self.send_spi(bytearray([0x2B]),False) # set Row addr command
self.send_spi(ustruct.pack(">HH", y0, y1), True) # y_end
self.send_spi(bytearray([0x2C]),False) # set to write to RAM
#chuck size can be increased for faster wiring to the screen at cost of RAM
def load_image(self, image_file, chunk_size=1024):
BMP_file = open(image_file , "rb")
data = BMP_file.read(54) #seek position past header
data = BMP_file.read(chunk_size)
while len(data)>0 : #read data from file to SPI
BMP_file.close()
