Sry but I’m having some trouble understanding the sensor.c file. What do these 6 lines of code do?
1469 if (streaming_cb && doublebuf && image->pixels != NULL) {
// Call streaming callback function with previous frame.
// Note: Image pointer should Not be NULL in streaming mode.
1472 streaming = streaming_cb(image);
Is this the function that calls the camera for the image? Where is streaming_cb defined?
1481 if (DCMI->CR & DCMI_JPEG_ENABLE) {
1482 __HAL_DCMI_ENABLE_IT(&DCMIHandle, DCMI_IT_FRAME);
These two lines only applies if the sensor format is JPEG right?
1487 for (tick_start = HAL_GetTick(); waiting_for_data; ) {
1488 __WFI();
Where are HAL_GetTick() and __WFI() defined? I searched the entire repo for these two functions but couldn’t find them. Is this just a timer? If so, where does the actual image transfer happen?
