PIR Shield to trigger capturing Image
I am currently working on a project where I would like to mimic a surveillance camera using:
  • PIR Shield
  • OpenMV Cam H7 Plus
I can capture images without a problem, but I can’t seem to figure out how to use the PIR shield as a trigger.
I removed the jumper for Pin 11 and soldered Pin 9 to use as wakeup pin since the Cam H7 Plus has no Pin 11?
I can set the white LED’s and the IR LED’s on the shield, but I get no reading of the PIR sensor itself.
Here is the code I am using:
import sensor
import pyb
record_time = 2000  # 2 seconds in milliseconds
debounce_time = 200  # Minimum time between detections in milliseconds
required_detections = 2  # Minimum number of consecutive detections to confirm motion
stream_counter = 0
sensor.reset()  # Reset and initialize the sensor.
sensor.set_pixformat(sensor.RGB565)  # Set pixel format to RGB565 (or GRAYSCALE)
sensor.set_framesize(sensor.QVGA)  # Set frame size to UXGA (1600x1200)
sensor.set_auto_gain(False)
sensor.set_framebuffers(3)
sensor.skip_frames(time=2000)  # Wait for settings to take effect initially
pir_pin = pyb.Pin("P9", pyb.Pin.IN, pull=pyb.Pin.PULL_UP)
white_led_pin = pyb.Pin("P7", pyb.Pin.OUT_PP)
    # The camera will now focus on whatever is in front of it.
    sensor.ioctl(sensor.IOCTL_TRIGGER_AUTO_FOCUS)
except:
    raise (Exception("Auto focus is not supported by your sensor/board combination."))
led = machine.LED("LED_RED")
led.off()
# Declare the stream variable here so it's accessible throughout the loop
stream = None
last_detection_time = 0
motion_confirmed = False
detection_count = 0
    # Check if the PIR sensor detects motion
    if pir_pin.value() == 0:
        # Check for debounce
        current_time = time.ticks_ms()
        if time.ticks_diff(current_time, last_detection_time) > debounce_time:
            last_detection_time = current_time
            # Confirm motion with multiple consecutive detections
            while detection_count < required_detections:
                detection_count += 1
            # Only confirm motion if required detections are reached
            if detection_count == required_detections:
                print("motion confirmed")
                white_led_pin.high()
                motion_confirmed = True
                detection_count = 0
    if motion_confirmed:
        # Start new recording and reset timers upon confirming motion
        if stream is None:  # Only open a new stream if one isn't already open
            stream_counter += 1
            stream = image.ImageIO("/stream_{:04d}.bin".format(stream_counter), "w")
            led.on()
            # Set the start time for recording
            start_time = time.ticks_ms()
        # Continue recording while motion is confirmed and within record_time
        while time.ticks_diff(time.ticks_ms(), start_time) < record_time:
            stream.write(img)
            # Calculate total recording time since the start of recording
            elapsed_time = time.ticks_diff(time.ticks_ms(), start_time) / 1000  # Milliseconds to seconds
            print("Recording time: {:.2f} seconds".format(elapsed_time))
        # Close stream after recording time expires
        stream.close()
        stream = None  # Reset stream to None so it can be reopened on the next motion
        led.off()
        motion_confirmed = False  # Reset motion confirmation after recording
        print("no motion detected")
        white_led_pin.low()
        detection_count = 0
My questions are:
  1. Is my idea possible of using the PIR shield as a trigger?
  2. Is there a mistake in my code?
  3. Is there an easy way I could check if my PIR sensor works?
Kindest regards
Hi, you need to apply some voltage to the RAW input pin on the shield. Just add a jumper between 3.3V and RAW and you should get a falling edge interrupt.
It works, thanks alot for the quick response!
