I’m adding a strobed 850 nm illuminator to an N6 and need the LED on only
during the sensor’s integration window.
The N6 pin reference says P10 is wired to “the camera sensor’s trigger /
exposure pin”, and notes that “some sensors can use the same pin as a
trigger input or an exposure output”. That output is what I’m after.
I know about IOCTL_SET_TRIGGERED_MODE, but it roughly halves
the frame rate and I need every fps I can get.
Can the PAG7936 drive an exposure/strobe output on P10, or is that pin
a trigger input only?
Thanks for adding this so quickly, much appreciated!
And regarding the new video about the “Hardware-in-the-Loop Server Rack”:
Am I correct in assuming that the ST VL53L9CX is being integrated? That would be great.
Is it possible to roughly estimate how long it takes to send a frame using an MM8108 on the N6? Of course, this depends heavily on the content, but just as a rough guide.
