Ibrahim, can you help on this?
Hi, here’s an example for pin control:
import sensor, image
from pyb import Pin
sensor.set_contrast(1)
sensor.set_gainceiling(16)
pin1 = Pin('P1', Pin.OUT_PP, Pin.PULL_DOWN)
pin1.value(0)
template = image.Image("/template.pgm")
while (True):
r = img.find_template(template, 0.70, step=4, search=SEARCH_EX)
if r:
pin1.value(1)
prasap1
23
Thank you sir
Its working
But without computer how can i use this.
I can upload program into OpenMV?
Yes, go to Tools → Save Script to OpenMV Cam.
Then after the script has been saved click the: Tools → Reset OpenMV Cam button.
prasap1
25
Thanks for quick support.
