OpenMV N6 RAW Current Limit
I’m designing a shield for the N6 and will be powering primarily two DC motors with a max stall current of 1.5A each. The system will be powered by a LiPo battery.
Can the raw pin deliver that much current? Is the only way to use the N6 to charge a battery to directly connect it to the JST connector?
Yes, the system can handle that, but it’s 1.5A total, not 3A. I’d not draw more than 1A from the RAW pin generally. You’re motor shield should probably power the camera through VIN. See the new motor shield designs we have: Driver Shield – OpenMV
Given you are making a new shield… just replicate the battery charger logic and etc. versus trying to use the onboard one at such a current level.
