Openmv file systems
MicroPython ports can provide implementations of FAT,littlefs v2, FAT is not tolerant to power failure during writes and this can lead to filesystem corruption and Littlefs is a filesystem designed for flash-based devices, and is much more resistant to filesystem corruption. Can openmv support Littlefs?
@iabdalkader
We use FAT because it works on PC. It should be possible to use any filesystem, you can change the firmware to do whatever you want.
I want to estimate micropython (Special openmv)can be a productivity tool whether or not. At present, the trouble is file would corrupted after a long time test.Also I realize that openmv IDE is the convenient and swift tools in micropython because the file system。
Yeah, you can change the file system to little fs by editing the firmware.
