I am wondering if the errors during run time are logged and can be accessed. Technically, I want to be able to retrieve errors that may occur during run time. This will help me to keep track of the error that occurs when the camera is deployed.
No all errors are logged, only critical ones (like failing to init the image sensor, SD etc…) and these are logged to the filesystem if it was found and mounted. You can try to catch specific exceptions and log them yourself to the filesystem.
Okay I see, thanks.
