Multiple RPC objects in Arduino?
I created an RPC object in Arduino as follows:
openmv::rpc_hardware_serial1_uart_master interface(115200);
That works fine. However, when I try to use that interface in a different .cpp file (within a function), I get an error telling me that ‘interface was not declared’.
So, I tried creating a different RPC object as follows:
openmv::rpc_hardware_serial1_uart_master mem_interface(115200);
When I try:
mem_interface.begin();
‘mem_interface’ is not recognized as a type.
Is it possible to create multiple RPC objects? If not, how can I use my ‘interface’ in other functions in other .cpp files?
Hi Peter,
It sounds like you are having issues with how C/C++ work. Please use Google or ChatGPT to answer your questions more quickly in this case.
Anyway, you need to extern the class name if you want to access it in a different file.
This is a compiler error where the real error is hidden behind a secondary error. Something is wrong with that declaration and you are getting a second error about the mem_interface missing because the first error caused it to not be created.
Thank you! I knew it was a compile issue, and thought I’d ask on here first to see if anyone had a quick answer before scouring the internet. I appreciate the quick response.
