Load .bmp file from flash memory
Hello!
I’ve saved a numpy array (400,400,3) to .bmp file and the format is RGB565. But when I tried to load the .bmp file from flash memory and created an Image object, I found the byte length of the Image object is quite wierd (32000 instead of 48000 for RGB565 image).
img = image.Image(‘sample_4.bmp’, buffer=bytes, copy_to_fb=True)
    print('img size: ', img.size())
    # Preprocess
    h = img.height()
    w = img.width()
    print('H x W: ', h, w)
    x_scale = self.crop_size / h
    y_scale = self.crop_size / w
    img.scale( x_scale= x_scale,
               y_scale = y_scale,
               roi = None,
               rgb_channel = -1,
               alpha= 256,
               color_palette=None,
               alpha_palette=None,
               hint = 0,# nearest interpolation
               copy = False,
               copy_to_fb = False)
    # Image2array
    img_array = np.frombuffer(img, dtype=np.int8)
    print(img_array.shape)
And the output of print shows:
img size: 320000
H x W: 400 400
(20000,)
Why img.size() can be 320000 instead of 4004003=480000? And why after scaling, the byte length becomes 20000 instead of 30000 (which looks like one of the RGB channel is missing)?
PS: The following python scripts are how I generate my .bmp files:
def save_bmp(filename, img):
width, height, channels = img.shape
row_size = (width * channels + 3) // 4 * 4  #
pixel_data = img.tobytes()
bmp_header = struct.pack('<2sIHHIIIIHHIIIIII',
    b'BM',                            # BMP
    54 + row_size * height,
    0, 0,
    54,
    40,
    width, height,
    1,
    channels * 8,
    0,
    row_size * height,
    0,
    0,
    0,
    0)
with open(filename, 'wb') as f:
    f.write(bmp_header)
    f.write(pixel_data)
for i in range(num_samples):
img = torch.tensor(extracted_images[i], dtype=torch.float32)
img = fivecrop_scale(img, crop_size=450)
img = img.permute(1, 2, 0)
img_array = img.numpy()
print('Permuted Image Shape:', img.shape)
img_bmp = cv2.flip(img_array, 0)
img_bmp = (img_bmp * 255).astype(np.uint8)
print("Image shape:", img_bmp.shape)  # (height, width, 3)
save_bmp(f'/data/sample_{i+1}.bmp', img_bmp)
Hi, the way you are trying to use the Image object isn’t supported.
Buffer is not applicable here. So, it will just be loaded from disk into the frame buffer because you passed copy_to_fb.
(400,400,3) is an RGB888 image. It’s 480,000 bytes… with 3 bytes per pixel. RGB565 is 2 bytes per pixel. (400,400,2) == 320,000
Thank you for your feedback and suggestions! I appreciate your insights regarding the following points:
  1. Image Format:
Before saving my data into .bmp file, I’ve checked the dimension of the img to be (H,W,3), and I wonder why the following loading method would also lead to 2 channel Image object (RGB565)
img = image.Image('sample_4.bmp', copy_to_fb=True)
print('img size: ', img.size()) # This output will be 20000 for my saved (100,100,3) .bmp file image
  1. Load a 3-channel RGB image with specific height and width:
Is there a better way to load a 3-channel RGB image with specified height and width, aside from using .bmp format, for input into a neural network, since loading .png/.jpg results in reshape error for compressed bytes length (usually for (100,100,3), the byte length would be smaller than 30000)
# Load image from .png file
# and scale the image to specific height and width
img = image.Image('sample_3.png', copy_to_fb=True)
# Preprocess
h = img.height()
w = img.width()
           y_scale = y_scale,
           roi = None,
           rgb_channel = -1,
           alpha= 256,
           color_palette=None,
           alpha_palette=None,
           copy = False,
           copy_to_fb = False)
# Image2array
  del img
  img_array = img_array.reshape((1, 3, 100, 100))
Error occurs since the size of img_array is smaller than 30000.
Hi, RGB565 is not 2 channels. It’s 2 bytes per pixel. RGB888 is 3 bytes per pixel.
We do not support RGB888 in our firmware except to load and convert it to RGB565, when you cast the RGB565 image to a ulab array it will become an 3 channel ndarray. However, our code otherwise does everything using RGB565 as it’s more efficient data processing-wise as each pixel is 16-bits so we can work on multiple pixels at a time in a 32-bit reg or 128-bit vector reg.
Regarding neural network conversion. We have a preprocessing module that does this for you: ml.preprocessing — ML Preprocessing — MicroPython 1.24 documentation
What are you trying to do exactly? If it’s to pass the image object to the ml module you just have to do:
img = image.Image(‘sample_4.bmp’, copy_to_fb=True)
list_of_ndarray_tensors = ml.predict([img])
The normalization object is automatically created for you inside the predict call.
Thank you so much! I‘ve tried this before but the input shape is not supported for my model, since the model requires an input of shape(1,3,H,W).
And I tried another method for loading image from .bmp files to my model, and it works, though the prediction accuracy seems bad.
def __getitem__(self):
    if self.index >= len(self.image_files):
        self.index = 0  #
    img_file = self.image_files[self.index]
    print('loading')
    img = image.Image(img_file, buffer=bytes, copy_to_fb=False)
    # Preprocess
    h = img.height()
    w = img.width()
               y_scale = y_scale,
               roi = None,
               rgb_channel = -1,
               alpha= 256,
               color_palette=None,
               alpha_palette=None,
               hint = image.BILINEAR,
               copy = False,
               copy_to_fb = False)
    # Image2array
    img_nd = img.to_ndarray(dtype="b", buffer=None).transpose()
    # Convert RGB2numpy
    img_array = np.zeros((1, img_nd.shape[0], img_nd.shape[1], img_nd.shape[2]), dtype=np.int8)
    img_array[0, :, :, :] = img_nd.copy()
    del img, img_nd
    self.index += 1
    valid_samples = []
    valid_samples.append(img_array)
    del img_array
    return valid_samples
Here’s how the normalization code works: openmv/scripts/libraries/ml/ml/preprocessing.py at master · openmv/openmv · GitHub
You can make your own wrapper class that’s customized and pass it to predict.
Please see the documentation on the predict for more information about what’s going on.
