# Letpon 3 vs Lepton 3.5
**URL:** https://forums.openmv.io/t/letpon-3-vs-lepton-3-5/1664
**Category:** OpenMV Boards
**Created:** [March 6, 2020, 3:40pm UTC](https://forums.openmv.io/t/letpon-3-vs-lepton-3-5/1664 "2020-03-06T15:40:42Z")
**Posts on this page:** 3
**Page:** 1
<div class="post-metadata">
### Author: ![GL-ITC](https://avatars.discourse-cdn.com/v4/letter/g/7993a0/32.png) [@GL-ITC](https://forums.openmv.io/u/GL-ITC)
#### Post date: [March 6, 2020, 3:40pm UTC](https://forums.openmv.io/t/letpon-3-vs-lepton-3-5/1664/1 "2020-03-06T15:40:42Z")
</div>
Hi
In your example code for getting the temperature of an object you say it may not work with other leptons because they do not have radiometry. What would be the difference if I was to use the Lepton 3.0 instead of the 3.5. Does it mean I cannot get a temperature value for an object? I have somehow managed to really confuse myself on this. I’m currently using a Lepton 3.5 but am wondering if a 3.0 would suffice.
### Author: ![kwagyeman](https://yyz1.discourse-cdn.com/flex029/user_avatar/forums.openmv.io/kwagyeman/32/4_2.png) [@kwagyeman](https://forums.openmv.io/u/kwagyeman)
#### Post date: [March 6, 2020, 4:54pm UTC](https://forums.openmv.io/t/letpon-3-vs-lepton-3-5/1664/2 "2020-03-06T16:54:25Z")
</div>
The Lepton 3.0 outputs an uncalibrated temperature image. If you try to use it the temperatures in the image will drift all over the place. Functional, it generates the same data formats as the 3.5 but the quality of the data isn’t there.
#### Post date: [March 6, 2020, 5:48pm UTC](https://forums.openmv.io/t/letpon-3-vs-lepton-3-5/1664/3 "2020-03-06T17:48:39Z")
</div>
Perfect, thank you.
