# Issue with external interrupt
**URL:** <https://forums.openmv.io/t/issue-with-external-interrupt/577>\
**Category:** OpenMV Boards\
**Created:** [February 14, 2018, 11:58pm UTC](https://forums.openmv.io/t/issue-with-external-interrupt/577 "2018-02-14T23:58:41Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![sebastian](https://avatars.discourse-cdn.com/v4/letter/s/4da419/32.png) [@sebastian](https://forums.openmv.io/u/sebastian)\
**Post date:** [February 14, 2018, 11:58pm UTC](https://forums.openmv.io/t/issue-with-external-interrupt/577/1 "2018-02-14T23:58:41Z")
</div>
I’m attempting to trigger a snapshot every time the camera receives a TTL pulse. I keep getting the same error which I believe is related to pin allocation:
> ValueError: ExtInt vector 14 is already in use
. Below is my code.
```python
import sensor, image, time
from pyb import Pin, ExtInt
syncFlag = 0
def callback (line):
    syncFlag = 1
    ext = ExtInt(Pin('P0'), ExtInt.IRQ_RISING, Pin.PULL_UP, callback)
    if (syncFlag == 1):
        img=image.snapshot()
        syncFlag = 0
**Post date:** [February 15, 2018, 12:59am UTC](https://forums.openmv.io/t/issue-with-external-interrupt/577/2 "2018-02-15T00:59:46Z")
</div>
Don’t create the interrupt in the loop. Make it outside of the loop.
