# IDE Disconnect
**URL:** <https://forums.openmv.io/t/ide-disconnect/306>\
**Category:** OpenMV Boards\
**Created:** [June 16, 2017, 8:37pm UTC](https://forums.openmv.io/t/ide-disconnect/306 "2017-06-16T20:37:33Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![DaddyOh](https://avatars.discourse-cdn.com/v4/letter/d/bbe5ce/32.png) [@DaddyOh](https://forums.openmv.io/u/DaddyOh)\
**Post date:** [June 16, 2017, 8:37pm UTC](https://forums.openmv.io/t/ide-disconnect/306/1 "2017-06-16T20:37:33Z")
</div>
Not sure if this is related to the other post on IDE disconnects.
12 files on the SD card and this program is supposed to loop through them and look for blue blobs.
IDE 1.6.0
Windows 8 system
board is running latest firmware.
Ii never completes all 12 files and the images never display in the framebuffer. The first several images are not expected to have blue blobs.
```python
import sensor
import sys
threshold_index = 2 # 0 for red, 1 for green, 2 for blue
              (0, 100, 27, 55, 75, -60)] # generic_blue_thresholds
sensor.snapshot()
print("=== start ===")
file_path = "/ftc/2016images/tests"
files = os.listdir(file_path)
print(files)
for file in files:
    full_file = '/'.join((file_path, file))
    print(full_file)
    img = image.Image(full_file, copy_to_fb=True)
    i = 0
    for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold=20, area_threshold=20, merge=True):
        i = i + 1
        img.draw_rectangle(blob.rect(), color=(255,0,0))
        img.draw_cross(blob.cx(), blob.cy(), color=(255,0,0))
        print(i)
    sensor.snapshot()
The output is inconsistent
```python
=== start ===
['gears_bright.bmp', 'gears_dark.bmp', 'gears_identical.bmp', 'legos_bright.bmp', 'legos_dark.bmp', 'legos_identical.bmp', 'plyers_bright.bmp', 'plyers_dark.bmp', 'plyers_identical.bmp', 'wheels_bright.bmp', 'wheels_dark.bmp', 'wheels_identical.bmp']
/ftc/2016images/tests/gears_bright.bmp
=== start ===
/ftc/2016images/tests/gears_dark.bmp
/ftc/2016images/tests/gears_identical.bmp
Any help you can provide would be appreciated.
Eric aka DaddyOh
**Post date:** [June 17, 2017, 1:27am UTC](https://forums.openmv.io/t/ide-disconnect/306/2 "2017-06-17T01:27:39Z")
</div>
Can you upload a test package? Also, did you install the latest IDE? If not then yo’re getting hit by the 40 ms timeout. This is causing the IDE to disconnect but your script should run fine.
**Post date:** [June 17, 2017, 1:28am UTC](https://forums.openmv.io/t/ide-disconnect/306/3 "2017-06-17T01:28:16Z")
</div>
The latest IDE being the one I posted on the forums you alluded too. Going to do a patch release for the IDE this weekend.
**Post date:** [June 17, 2017, 4:00am UTC](https://forums.openmv.io/t/ide-disconnect/306/4 "2017-06-17T04:00:21Z")
</div>
Here’s the link: [http://upload.openmv.io/openmv-ide-windows-1.7.0/openmv-ide-windows-1.7.0.exe](http://upload.openmv.io/openmv-ide-windows-1.7.0/openmv-ide-windows-1.7.0.exe)
**Post date:** [June 17, 2017, 10:43am UTC](https://forums.openmv.io/t/ide-disconnect/306/5 "2017-06-17T10:43:15Z")
</div>
Thanks. Runs perfect now. I really appreciate the fast response.
Eric
