How to solve "MemoryError: memory allocation failed, heap is locked"?
I connect LSM9DS1 IMU breakout to I2C(2) of OPENMV3. IMU can be read successfully by codes below :
bus = I2C(2)
lsm = LSM9DS1(bus)
while (True):
print(‘Accelerometer: x:{:>8.3f} y:{:>8.3f} z:{:>8.3f}’.format(*lsm.read_accel()))
print(‘Magnetometer: x:{:>8.3f} y:{:>8.3f} z:{:>8.3f}’.format(*lsm.read_magnet()))
print(‘Gyroscope: x:{:>8.3f} y:{:>8.3f} z:{:>8.3f}’.format(*lsm.read_gyro()))
print(“”)
I try to use timer callback to read IMU as below codes, MemoryError occurred, however.
def sensor_read(timer):
print(" *** *** ***")
bus = I2C(2)
lsm = LSM9DS1(bus)
tim = Timer(2, freq=1) # create a timer object using timer 2 - trigger at 1Hz
tim.callback(sensor_read) # set the callback to read LSM9DS1
while (True):
How to solve “MemoryError: memory allocation failed, heap is locked” ?
Thanks for your support,
Issue solved by following code -
micropython.heap_unlock()
