Hi, this has been described before on the forum. It’s pretty detailed on what you need to do. I’d appreciate if you search for the previous answer.
Also, you may wish to take a look at how py_lcd.c is compiled into the firmware. If you search for py_lcd and similar strings in the repo using grep you should get an idea on what you have to do.
