I am using OpenMV on an Arduino Nicla Vision and am trying to use the machine.I2C class.
From the TOF sensor example I can see that the I2C ID is 2
from machine import I2C tof = VL53L1X(I2C(2))
Where can I find that ID in the documentation?
I was trying to use the external I2C port (the one on the header) and I determined by trial and error that it’s ID was 1.
I assume that is in a config file somewhere ,but don’t know where to look.
I can see some reference to I2C_ID in the file openmv/omv_boardconfig.h at master · openmv/openmv · GitHub, but I don’t see a value for the TOF sensor and ID =1 is the FIR (not sure what this is on the Nicla Vision) #define FIR_I2C_ID (1)
Ok, thx. I can see the I2C connections on the schematic.
I was just thinking that since the OpenMV IDE handles multiple boards that there must be a file that indicates what the IDs are for the different boards. Like the variant pin files on the Arduino IDE.
I thought the file that I referenced “openmv/src/omv/boards/NICLAV/omv_boardconfig.h” was the correct place to look, but it doesn’t correlate exactly to the schematic. I’ll just accept that there is some sort of magic that gets that done.
