I have a custom H7 plus board which already had working but changed flash and sdram to different PN in theory compatible. W25Q256JVEIQ and IS42S32800J-6TL.
I manage to load the firmware however when I plug in the Openmv I hear the device USB device enumerate, quickly see the USB symbol on the connect button and then it disappears. LED flashes blue at a high frequency I guess 10 Hz. Not slow blinking blue as usual when openmv is on waiting for connection.
Does anybody know what flash blinking blue means so I can debug?
Good to know thanks. I was told by the manufacturer that IS42S32800J-6TL was form fit function replaceable part for obsolete IS42S32800B-6T. Is it the case that MICROPY_HW_SDRAM_TIMING_TMRD (2) means CAS Latency 2 for the newer chip (see table) and is actually correct?
Thanks. Do you have experience with that chip I mention being the other is obsolete and if so do you know as a fact that I need to change the timings? I would approcciate if you let me know as I have a bit of a “situation” which I need to solve quickly.
Could take days to figure out and it might be the problem is elsewhere.
It is, but, you asked me to run the calculations for you on it versus asking me to double check. I provided the link to the values that need to be confirmed and told you how to do it.
Sorry I didn’t and never would ask you to run calculations. Was asking if you used that chip before and knew that it wasn’t form fit function compatible without having to change firmware.
In the meantime I managed to connect to the OpenMV via pc by loading an older firmware version 3.9.2. No blinking blue light.
When I try to connect I am prompted to upgrade firmware . If I don’t I can connect and do stuff. I tried to access sdram and I get a failure not enough memory . So indeed the timing is probably an issue.
With 3.9.2 firmware you can connect at least with IDE. With 3.9.4 up you get the fast blue light upon power on. I think the “Fix linker script stack allignment for boards with SRAM” might be making some checks and panics when it doesn’t find the sdram. Tomorrow I will try to compile without that change and tell you what I get.
Friday I’m getting two of the same boards , one with the old flash and one with the new one. Could be I got unlucky with the bga. How many boards do you have with same configuration?
Hello, I have built an identical board with the obsolete SRAM. It works. The two chips should be identical according to the manufacturer. @kwagyeman any hints? If you are intending to make more H7plus and cannot find that obsolete chip, we can help.
