# FLIR Lepton Framerates - Best Version?
**URL:** <https://forums.openmv.io/t/flir-lepton-framerates-best-version/1876>\
**Category:** OpenMV Boards\
**Created:** [August 12, 2020, 7:36pm UTC](https://forums.openmv.io/t/flir-lepton-framerates-best-version/1876 "2020-08-12T19:36:08Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![CRMANN](https://yyz1.discourse-cdn.com/flex029/user_avatar/forums.openmv.io/crmann/32/58_2.png) [@CRMANN](https://forums.openmv.io/u/CRMANN)\
**Post date:** [August 12, 2020, 7:36pm UTC](https://forums.openmv.io/t/flir-lepton-framerates-best-version/1876/1 "2020-08-12T19:36:08Z")
</div>
I’d like to start experimenting with the Lepton + OpenMV, however after watching your video testing the various models, I want to check my understanding of the various performance differences.
My takeaway is that the only Lepton that could provide an uninterrupted/near 30fps framerate is the 1.x variants, anything 2.x or 3.x has much slower rates and “freezes” due to FFC. Is this a correct assessment?
**Post date:** [August 12, 2020, 8:05pm UTC](https://forums.openmv.io/t/flir-lepton-framerates-best-version/1876/2 "2020-08-12T20:05:24Z")
</div>
It outputs 9 fps per ITAR restrictions because you could build a heat seeking missile with it. All do 9 fps of actual data. The FLIR lepton 1 just outputs the same frame about 3x times that makes the fps appear higher.
**Post date:** [August 12, 2020, 8:59pm UTC](https://forums.openmv.io/t/flir-lepton-framerates-best-version/1876/3 "2020-08-12T20:59:14Z")
</div>
I was suspecting it was indeed and ITAR thing. Was I also correct about the constant flat field correction? Can that be avoided if I am not interested in temp measurment, and only interested in the thermal “scene”?
**Post date:** [August 12, 2020, 9:31pm UTC](https://forums.openmv.io/t/flir-lepton-framerates-best-version/1876/4 "2020-08-12T21:31:24Z")
</div>
No, it’s necessary because the sensor drifts. So, it has to run as the sensor temp changes. It runs more often on power on.
**Post date:** [August 13, 2020, 6:09am UTC](https://forums.openmv.io/t/flir-lepton-framerates-best-version/1876/5 "2020-08-13T06:09:56Z")
</div>
I appreciate the insight, should make picking the right lepton a bit easier!
