# dithering
**URL:** <https://forums.openmv.io/t/dithering/251>\
**Category:** OpenMV Boards\
**Created:** [May 3, 2017, 6:22am UTC](https://forums.openmv.io/t/dithering/251 "2017-05-03T06:22:44Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![ticapix](https://avatars.discourse-cdn.com/v4/letter/t/ebca7d/32.png) [@ticapix](https://forums.openmv.io/u/ticapix)\
**Post date:** [May 3, 2017, 6:22am UTC](https://forums.openmv.io/t/dithering/251/1 "2017-05-03T06:22:44Z")
</div>
I’m trying to apply some dithering algo to an image with that code, but the set\_pixel function doesn’t seem to have any effect.
```python
# Hello World Example
import sensor, image, time, lcd
sensor.set_framesize(sensor.QQVGA) # Set frame size to QVGA (320x240)
sensor.skip_frames(10) # Wait for settings take effect.
lcd.init()
kernel_2x2 = [[0, 2], [3, 1]]
def coef(kernel, i, j):
    return 255 * (1 + kernel[i][j]) / (1 + len(kernel) * len(kernel[0]))
def ordered_dithering(img, kernel):
    height_img, width_img =(img.height(), img.width())
    height_kernel, width_kernel = (len(kernel), len(kernel[0]))
    for x in range(width_img, width_kernel):
        for y in range(height_img, height_kernel):
            for i in range(width_kernel):
                for j in range(height_kernel):
                    pixel = 255 if img.get_pixel(x + i, y + j) < coef(kernel, i, j) else 0
                    img.set_pixel(x + i, y + j, pixel)
    img.draw_string(0, 0, "h: %d, w: %d" % (height_img, width_img))
    img.draw_string(0, 10, "h: %d, w: %d" % (height_kernel, width_kernel))
    return img
    bw = ordered_dithering(img, kernel_2x2)
    lcd.display(bw)
On the lcd, I can see the text, but pixel values are not changing. Do I miss something ?
**Post date:** [May 3, 2017, 1:25pm UTC](https://forums.openmv.io/t/dithering/251/2 "2017-05-03T13:25:52Z")
</div>
```python
img.set_pixel(x, y, 255)
This should work, just tested it. Um, it does clip drawing if you are off screen. Can you check that?
**Post date:** [May 3, 2017, 7:22pm UTC](https://forums.openmv.io/t/dithering/251/3 "2017-05-03T19:22:24Z")
</div>
No, it doesn’t help.
I reduced the size of the code to try to narrow down the root cause, but it doesn’t help
```python
import sensor, lcd
sensor.skip_frames()
lcd.init()
    for x in range(100, 2):
        for y in range(100, 2):
    img.draw_line((0, 0, 10, 10))
    lcd.display(img)
With that code, I don’t see the dots on neither the LCD nor the preview in the IDE.
I only see the white diagonal on the preview in the IDE, not on the LCD.
Any clue ?
**Post date:** [May 3, 2017, 7:58pm UTC](https://forums.openmv.io/t/dithering/251/4 "2017-05-03T19:58:23Z")
</div>
Mmm, looks like your resolution is wrong. You need to use QQVGA2. Otherwise the image gets cropped to just the center of it.
[http://docs.openmv.io/library/omv.sensor.html#sensor.sensor.QQVGA2](http://docs.openmv.io/library/omv.sensor.html#sensor.sensor.QQVGA2)
BTW, did you update the firmware?
**Post date:** [May 4, 2017, 5:38am UTC](https://forums.openmv.io/t/dithering/251/5 "2017-05-04T05:38:32Z")
</div>
I prefer QQVGA because it keeps a correct aspect ratio when rotating the LCD in landscape mode.
Using QQVGA2, I can see the white diagonal on the LCD too, but I still don’t see the dots set with set\_pixel.
I have a M4 OV7725 with firmware 2.3.0 (IDE 1.5.2)
Is there a reason py\_image\_draw\_line is using imlib\_draw\_line, but py\_image\_set\_pixel is reimplementing part of imlib\_set\_pixel directly using the IM\_\* defines ? (maybe to handle the p arg?)
**Post date:** [May 4, 2017, 1:28pm UTC](https://forums.openmv.io/t/dithering/251/6 "2017-05-04T13:28:10Z")
</div>
> ```python
> Any clue ?
Yes:
```python
range(start, stop[, step])
**Post date:** [May 4, 2017, 5:27pm UTC](https://forums.openmv.io/t/dithering/251/7 "2017-05-04T17:27:59Z")
</div>
silly me … 😊
It works. As for the diagonal not being visible on the lcd with QQVGA, it’s only due to the crop to fit the screen.
