Connect to OpenMV
I can not connect to OpenMv OpenMV Cam RT1062
suddenly the icons at the bottom left turned gray, even though I can see the files in the file explorer
Hi, the connect icon has the USB logo on it. It should be clickable. Which IDE version are you using, and what have you selected under Tools?
Thanks kwagyeman
Problem is solved, it was an error in the main.py
a new copy worked fine
