Confidence Level in serial print
Hello, I built a model with edge impulse for object recognition. I saw that I can change the confidence level in the code. Does this indicate how secure it is with the output of the object? And how can I have this confidence level as an output in the serial print?
I am using open mv h7 cam.
The model outputs it’s confidence level. Then in the code we are just thresholding it.
When you do print() the message of whatever you want it output.
