I have a new OpenMV AE3 and am unable to connect it to OpenMV IDE 5.1.1 on Windows. The IDE says “No camera found” and then gets stuck on “Reconnect your OpenMV Cam…”.
Windows Device Manager shows “Camera DFU Device” with hardware ID USB\VID_30C9&PID_00CD&MI_04. The camera’s LED first turns green, then blinks blue but no OpenMV drive or camera COM port appears.I tried the IDE’s firmware recovery options and downloaded the AE3 firmware ZIP, but it still does not work.
I have run into the issue as well. But found that what works most of the time is to power off the AE3 and the power it back on. Then I make sure that the little blue light stops blinking fast and then I connect.
Thankyou! I have tried that but, for me, the little blue light never stops blinking once the camera is powered on. And if I remove the USB cable and power the camera off and then back on, the blue light starts blinking fast again and fails to connect. I have tried several times and I have not been able to connect the camera once yet
Most likely the issue is a windows driver issue. The camera is fine given the blue light blinking. Do you see any devices appear under unknown USB devices or etc.
Also, if you’d like to schedule a live debug session I can do that.
Thankyou! I think a live debug session would be helpful at this point, as I cannot see any other USB devices that could be the AE3 in the device manager. I´ll PM you directly
