# Camera FOV
**URL:** <https://forums.openmv.io/t/camera-fov/1280>\
**Category:** OpenMV Boards\
**Created:** [May 30, 2019, 6:18pm UTC](https://forums.openmv.io/t/camera-fov/1280 "2019-05-30T18:18:43Z")\
**Posts on this page:** 8\
**Page:** 1
<div class="post-metadata">
**Author:** ![ScottM](https://avatars.discourse-cdn.com/v4/letter/s/65b543/32.png) [@ScottM](https://forums.openmv.io/u/ScottM)\
**Post date:** [May 30, 2019, 6:18pm UTC](https://forums.openmv.io/t/camera-fov/1280/1 "2019-05-30T18:18:43Z")
</div>
I’d like know what the horizontal and vertical field of view is for the stock lens (in degrees). I need to use the camera at close range to read QR Codes or April tags that are potentially only a few inches away.
**Post date:** [May 30, 2019, 7:25pm UTC](https://forums.openmv.io/t/camera-fov/1280/2 "2019-05-30T19:25:00Z")
</div>
This is listed on the website product pages for each lens and and the OpenMV Cam H7 camera.
**Post date:** [May 30, 2019, 7:30pm UTC](https://forums.openmv.io/t/camera-fov/1280/3 "2019-05-30T19:30:37Z")
</div>
I missed it. I’ll look again. Thanks.
**Post date:** [May 30, 2019, 7:41pm UTC](https://forums.openmv.io/t/camera-fov/1280/4 "2019-05-30T19:41:12Z")
</div>
I just found the page with lens specifications. Duh.
**Post date:** [May 30, 2019, 7:55pm UTC](https://forums.openmv.io/t/camera-fov/1280/5 "2019-05-30T19:55:16Z")
</div>
On the bottom of the product page for the H7 there’s a table with system specs. This lists the lens FoV.
**Post date:** [May 30, 2019, 7:57pm UTC](https://forums.openmv.io/t/camera-fov/1280/6 "2019-05-30T19:57:36Z")
</div>
> **[Lenses](https://openmv.io/collections/lenses)**
> You can change your OpenMV Cam's vision by using different lenses. We've done the hard work to source a variety of lenses for different applications you may want to use your OpenMV Cam for. If the lens you need is not available from us then please...
This lens gives your OpenMV Cam the ability to see a wider field-of-view (FOV). The standard lens that ships with your OpenMV Cam has a 115° FOV which is good, but, not great for security applications. This lens has a 185° FOV so your OpenMV Cam can literally see behind itself.
**Post date:** [May 30, 2019, 9:06pm UTC](https://forums.openmv.io/t/camera-fov/1280/7 "2019-05-30T21:06:52Z")
</div>
There’s a specs table on each lens product page that has info like:
Specifications
Focal Length12mm
ApertureF2.0
Format1/3"
MountM12\*0.5
**FOVH = 18.8°, VFOV = 14.0°**
IR Cut Filter650nm (removable)
Weight4g
Length14mm
Width14mm
Height15mm
The above is for the telephoto lens. There’s a table link this on each product page.
**Post date:** [May 30, 2019, 9:07pm UTC](https://forums.openmv.io/t/camera-fov/1280/8 "2019-05-30T21:07:22Z")
</div>
Oh, that text might be outdated.
