Hello, I am Planning to use openMV cam in industrial rejection systems, meaning it will help detect flaws in a printed batch code(text), QR code or bar code while the print packets will continuously pass with a gap of about 10mm in-between each other at a speed of 35-40 meters/min form under the cam. openMV cam will need to analyze at most 20 codes per sec. the cam will be fixed at a constant height(no more than 200mm) facing the conveyor belt and will have abundant light exposure to work with while operating. the cam may be continuously used 3-4 hours at a time. please let me know, if openMV can be used for such application or not, and if so, how will it perform. thank you.
Yes, we’ve had customers do this using the Global Shutter Camera module with the OpenMV Cam H7 Plus. You need to keep the resolution low and focus the lens precisely, but, otherwise, it works.
