Frame Rate April Tags
tobias1234
Postby tobias1234 » Thu Oct 11, 2018 3:58 pm
what kind of frame rates are there to expect for april tag pose estimation at VGA resolution with the new H7?
Cheers
Tobias
Re: Frame Rate April Tags
Postby kwagyeman » Thu Oct 11, 2018 6:39 pm
April Tags runs at 240x240 max on the H7 at about 20 FPS.
The AprilTag algorithm has a rather large memory overhead that scales exponentially with resolution. Anyway, in order to get more RAM for the algorithm I locked the res to 256x256 at max. This allowed me to cut the size of the union find table by half allowing for higher reses than 160x120. But, this also limits the max res too.
ScottM
Postby ScottM » Tue Jun 11, 2019 11:23 am
I'm trying to maximize the frame size for detecting April tags. How do I set it for 256x256 when the sensor.set_framesize command doesn't have that as an option?
Alternatively, can I go with a larger frame size if I switch to Datamatrix or QR Codes?
Postby kwagyeman » Tue Jun 11, 2019 12:41 pm
Don't run at 256x256, stay at 240x240. Use the set_windowing method with a resolution of QVGA or higher. set the windowing to 240x240.
As for QrCodes, I believe that takes less RAM. Remember resolution is in 2-dimensions so going up to the next res is 4x more RAM.
ScottM
Postby ScottM » Thu Jun 13, 2019 12:38 pm
With respect to windowing, I understand, but I am getting an error. I entered the following lines;
sensor.set_windowing(240,240)
to create a 240x240 window centered inside a VGA frame. I get the following error.
TypeError: function takes 1 positional arguments but 2 were given
ScottM
Postby ScottM » Thu Jun 13, 2019 12:47 pm
I did a search and discovered a syntax error. I needed 2 sets of brackets. Why, I have no idea.
sensor.set_windowing((240,240))
ScottM
Postby ScottM » Thu Jun 13, 2019 1:09 pm
I found something disturbing. If I use windowing, I cannot decode April Tags. Why is this?
Scott
Postby kwagyeman » Thu Jun 13, 2019 1:19 pm
Hi, it requires brackets because the Python code expects a tuple of 2 or 4 length.
When you increase the AprilTag resolution the algorithm adjusts to the larger memory requirement by reducing a temporary heap size used to store edge point matches. Because this memory pool is smaller the algorithm runs out of RAM and reallocs fail. When this happens point structures it was iterating on are lost. I choose the algorithm to have this behavior versus throwing an error when this happens. The algorithm can start finding new April structures so it's not fatal for all tags in the image. Just large ones that are built from a long list of edge points.
In the H7 240x240 can be achieved. However, I recommend lowering the res to as low as you can get by with. The algorithm is exponentially memory hungry and our RAM did not grow by an exponential amount for the H7.
Postby kwagyeman » Thu Jun 13, 2019 1:21 pm
Um, try 200x200. That works well.
Note... we might be making an H7 version with RAM where this limit would be removed. The AprilTag algorithm doesn't actually need a lot of memory bandwidth so the external RAM and resolution would not necessary reduce performance.
ScottM
Postby ScottM » Thu Jun 13, 2019 4:46 pm
I think it would be great to have more RAM available. How about if we could use the micro SD card as memory with the caveat that we'd have to reduce the frame rate? I'd be fine with 5-10 fps if I could use the entire 640 x 480 sensor resolution. I'd use a 1 or 2 GB card.
Postby kwagyeman » Thu Jun 13, 2019 7:04 pm
SD Cards can't be used for RAM. Running at 200x200 is about the max the H7 can do with AprilTags. I'm sorry this isn't enough res.
If we have an H7 with RAM working soon I will send you a model. Then this limit will be removed.
ScottM
Postby ScottM » Tue Jun 18, 2019 11:55 am
I set the resolution to 200x200 and it runs for awhile and then I sometimes get a memory error that reads "Memory Error: Out of temporary Frame Buffer Heap Memory! Please reduce the resolution of the image you are running this algorithm on to bypass this issue". Instead of reducing the window size, is there a command I can run every so often to flush the memory buffer to prevent this from happening? Does what the camera sees affect the memory use?
Postby kwagyeman » Tue Jun 18, 2019 1:03 pm
Um, just wrap the code with a try: except: block.
AprilTags uses more RAM when it has to deal with edges. The less stuff there is in the image the less RAM it uses. The big RAM hog is that is allocates a 12 byte point structure per black/white edge transition. So, with 200x200 pixels it could need ~500KB or so. This along with the already static memory it needs of about 8x resolution for other memory structures. It's honestly crazy the algorithm runs on a MCU in SRAM.
ScottM
Postby ScottM » Tue Jun 18, 2019 1:17 pm
I see. So that's why it fails sometimes. I guess in those instances, the camera sees more edges. I can give you some information about what I'm trying to do. I want to buy a mecanum type robot and have the camera under it pointing down. On the floor, I want to place April tags space 4-6" apart in a grid. I want the camera to be able to see several in the FOV so that i can find the next tag and instruct the robot to move to it. Since height off the floor would only be a few inches, I need to maximize the window size to see more than one at a time. I was thinking of trying the wide angle lens, but I'm not sure if the distortion would be too much for the decoder.
In your opinion, is there a more memory efficient tag I could use, or is this a job for a more powerful system like a raspberry Pi?
Postby kwagyeman » Tue Jun 18, 2019 2:31 pm
Yeah, so, you don't need the resolution in this particular problem. Just the FoV. So, I'd use a wide angle lens. The algorithm used by AprilTags can decode tags that are warped. It doesn't need the tag to be squarish.
Since you don't need the resolution. Just get to the highest res you can using greyscale where len_corr() still works. Then run the AprilTag algorithm on the lens corrected image.
The AprilTag algorithm can find tags with very few pixels. It's quite robust. So, work on making the FoV big versus the resolution.
ScottM
Postby ScottM » Tue Jun 18, 2019 4:43 pm
Thanks Nyamekye for your responses. You are very helpful indeed. I should have bought the wide angle lens when I bought a couple of the cameras. I will order one and experiment with different size April Tags and the greyscale and lens correction settings you suggest. I will upload pictures and more information when I get to that stage.
Users browsing this forum: adisakin@hotmail.com and 1 guest
