AttributeError: 'Image' object has no attribute 'find_number'
fabianpedd
Postby fabianpedd » Mon Sep 10, 2018 6:57 pm
- edit: the example was outdated
Hey
first of all: Thank you very much kwagyeman. Great work. Very excited for the upcoming kickstarter! :)
However:
I am having some issues getting an example sketch running. :?
Example Sketch: find_numbers_1.py is giving me a hard time. The code looks like this:
# LetNet Example
import sensor, image, time
sensor.reset()                          # Reset and initialize the sensor.
sensor.set_contrast(3)
sensor.set_pixformat(sensor.GRAYSCALE)  # Set pixel format to RGB565 (or GRAYSCALE)
sensor.set_framesize(sensor.VGA)        # Set frame size to QVGA (320x240)
sensor.set_windowing((128, 128))        # Set 128x128 window.
sensor.skip_frames(time = 2000)         # Wait for settings take effect.
sensor.set_auto_gain(False)
sensor.set_auto_exposure(False)
    # NOTE: Uncomment to detect dark numbers on white background
    # img.invert()
    out = img.find_number(roi=(img.width()//2-14, img.height()//2-14, 28, 28))
    img.draw_rectangle((img.width()//2-15, img.height()//2-15, 30, 30))
    if out[1] > 5: # Confidence level
        print("Number: %d Confidence: %0.2f" %(out[0], out[1]))
In this line:
I am getting:
Setup:
  • IDE: 2.0.0
  • Cam: 3.0.0 [latest]
  • OS: Windows 10 Pro, 64 Bit, Version: 1803, Build: 17134.228
Other examples are running fine. Am I missing a library? Or something else? :roll:
Thanks in advance,
Fabian
Re: AttributeError: 'Image' object has no attribute 'find_number'
Postby kwagyeman » Mon Sep 10, 2018 7:05 pm
That method was removed after we got CNNs working. Where did you find that old code? It should have been temvoed from the release.
fabianpedd
Postby fabianpedd » Mon Sep 10, 2018 7:06 pm
- edit: already answered
Or has that method been removed already and the examples are just outdated?
http://docs.openmv.io/library/omv.image ... ind_number
fabianpedd
Postby fabianpedd » Mon Sep 10, 2018 7:10 pm
Ups, haha. My internet is kinda slow. Guess thats the answer then.
Saw you already removed the script from the repo. Thank you iabdalkader :)
Postby iabdalkader » Mon Sep 10, 2018 7:11 pm
Yes this is an outdated example, I just removed it. See 25-Machine-Learning/nn_lenet.py and the model is here:
https://github.com/openmv/openmv/raw/ma ... et.network
Postby kwagyeman » Mon Sep 10, 2018 7:14 pm
Lenet I think doesn't run in the M7 due to lack of RAM. On the H7 it runs great.
AK51
Postby AK51 » Wed Oct 10, 2018 4:15 am
My project is to look for a single digit number (with fix font style). There are mostly 3 digits in front of the camera and I need to select the biggest size. May I know which approach is good? For keypoint, how to get the array as blob and select the biggest size? Thx
Postby kwagyeman » Wed Oct 10, 2018 3:04 pm
The MNIST net is the best for this. Um, I'll train a smaller version of the net that will fit on the M7. We just got all our CNN code for training written down now.
AK51
Postby AK51 » Thu Oct 18, 2018 10:36 pm
Hi, may I know the schedule? Thx
I have ordered the H7 too, but it won't be here until March 2019, right?
Postby kwagyeman » Fri Oct 19, 2018 12:10 pm
It will probably come sooner. But, that's the latest time. The long-lead time part is buying the STM32H7 chips. We did a factory order of 10K.
