OpenMV H7
Discussion related to the OpenMV Kickstarter.
pyb_
OpenMV H7
Postby pyb_ » Sun Aug 12, 2018 8:50 am
Hello, huge fan of the OpenMV M7, and have purchased 2 of them so far. When will the OpenMV H7 Kickstarter campaign be launched? I can't hardly wait!
Re: OpenMV H7
Postby kwagyeman » Wed Sep 05, 2018 9:41 pm
Less than 2 weeks. The video is about ready! So, I just have to make some static web page updates over the weekend. Send out some emails. And launch it next week.
pyb_
Re: OpenMV H7
Postby pyb_ » Sat Sep 08, 2018 9:06 am
Awesome. Can't wait!
zalouvalou21
Re: OpenMV H7
Postby zalouvalou21 » Thu Sep 13, 2018 5:41 pm
Hello! This may be a stupid question, but I wonder if the FLIR adapter will be compatible with x.5 versions of lepton?
Re: OpenMV H7
Postby kwagyeman » Thu Sep 13, 2018 11:28 pm
All versions. We have a driver in software that supports everything (not really that hard)?
zalouvalou21
Re: OpenMV H7
Postby zalouvalou21 » Fri Sep 14, 2018 1:18 am
Yes, that was what I thought... Thank you! Nice work btw!
jl1982fm
Re: OpenMV H7
Postby jl1982fm » Fri Sep 14, 2018 6:22 am
Hi will what kind of MIPI connection will the OpenMV H7 have?
MIPI CSI 2.1? 4 lanes?
Waiting for the kickstarted to start
Re: OpenMV H7
Postby kwagyeman » Sat Sep 15, 2018 12:45 pm
Hi, it's a parallel interface. So, no MiPi cameras. This is fine however since we're not exactly going to be pushing super high resolutions. That said, if you want to build a product with the numerous low power camera modules popping up for always on camera applications our system works well for that.
Note that you can buy a crosslink fpga and build a parallel to MiPi bus converter for less than $10.
The interface on the H7 is a 8 bit standard data bus along with i2c lines and a SPI bus. Additionally, we added extra reserved pins for MiPi over the same connector standard in the future.
victagayun
Re: OpenMV H7
Postby victagayun » Wed Oct 17, 2018 5:22 am
Is this the camera module connector?
Do you have adapter connector to expose the pins?
Re: OpenMV H7
Postby kwagyeman » Sun Oct 21, 2018 6:13 pm
We don't have a plan to make one but you an easily build one once we release the schematics.
victagayun
Re: OpenMV H7
Postby victagayun » Fri Nov 02, 2018 9:10 pm
I am planning to order one more camera when the backetkit is sent out.
To save on expenses, I would hold on buying LCD and plan to use ILI9341 instead.
Will you be supporting that display?
Re: OpenMV H7
Postby kwagyeman » Sat Nov 03, 2018 12:25 am
Yeah, I have one on my desk to add LCD support for. Just need to get to it.
victagayun
Re: OpenMV H7
Postby victagayun » Sun Nov 04, 2018 9:22 pm
ANy reason why OV9650 was not used in H7?
I think the resolution is higher.
Would it be better?
Can we still use OV9650 on H7?
Re: OpenMV H7
Postby kwagyeman » Mon Nov 05, 2018 12:03 am
We don't have external SDRAM. So, it's not like we can do anything with a high res anyway. It's not really our goal. The OV7725 works and has a good supply. So, why switch...
That said, the camera module is removable now and we have driver support for that camera so it will work if you make a breakout board for it.
victagayun
Re: OpenMV H7
Postby victagayun » Thu Nov 15, 2018 9:18 am
Hey This might help
https://github.com/OutOfTheBots/OpenMV_TFT
kelapuress
Re: OpenMV H7
Postby kelapuress » Wed Jan 02, 2019 6:42 pm
What is the best way to get OPENMV H7 in Germany? Too much shipping via official site. Any other way?
Re: OpenMV H7
Postby kwagyeman » Wed Jan 02, 2019 8:14 pm
It's not released yet. Please back it on BackerKit (see link on the home page).
Texian1
Re: OpenMV H7 - USB not detected in Win10
Postby Texian1 » Wed May 08, 2019 6:34 pm
I am just getting around to the initial power up of my Kickstarter Cam H7.
Walking thru the OpenMV IDE install and first power up, My H7 seems to go thru the green/white/blue LED flash sequence and then just flashes blue, but I am not detecting it on Open MV.
the USB "drive" is not showing up nor is the USB port showing under my devices. Is there a specific driver that I need or need to update?
I tried shorting the Boot/RST lines per the instructions in Open MV, but still no joy.
Is this a bad board or drive issue? OR USB connector issue? A visual scan of the board under my microscope did not show any obvious opens or shorts.
I have a need for a people-counter project and this seems to be perfect for it, If I can get it to talk. I need to have it running in about 2-3 weeks.
Texian1
- Texian1 -
Postby iabdalkader » Wed May 08, 2019 7:47 pm
Texian1
If the board flashes blue it means all good, can you try another USB cable ?
Re: OpenMV H7
Postby kwagyeman » Thu May 09, 2019 1:59 pm
You most likely are using a power only USB cable.
Texian1
Re: OpenMV H7
Postby Texian1 » Thu May 09, 2019 2:38 pm
After going thru no less than 8 cables, one finally work! I use several of these with other Arduino and ESP32 boards with out issue. Guess I need to clean house.
thanks guys, I knew it had to be something simple, but only 1 of 8 cables working was unexpected, arrrrrgh!
My next step is getting an Rpi "people counter" running on this board. I have a couple of examples for the Rpi, but the libraries will be need to be modified for use with microPython.
- Texian1 -
Re: OpenMV H7
Postby kwagyeman » Thu May 09, 2019 2:45 pm
I don't know how you will do people counting. Um, I guess you can use blob detection via frame differencing and count the blobs.
Return to “Kickstarter Topics”
