Advanced Iris Tracking Software
Re: Advanced Iris Tracking Software
Postby kwagyeman » Tue Apr 17, 2018 1:38 pm
Only one program can read the serial port at a time. But, once you have the script working in OpenMV IDE... Save the script to the camera, reset the camera, and then open the serial port in another application.
s-bbrackett
Postby s-bbrackett » Fri Apr 20, 2018 3:06 pm
I guess if you want a simpler answer, I simply want to take data off of the camera and onto visual studios.
s-bbrackett
Postby s-bbrackett » Fri Apr 20, 2018 3:07 pm
Sorry I didn't see your last post. So, I can write just a print statement and use the IDE terminal with the saved code and it will pickup on VS?
Postby kwagyeman » Fri Apr 20, 2018 7:33 pm
Yes.
Note: On opening the VCP port make the DTR line active. The MicroPython OS will not print data unless this is active.
s-bbrackett
Postby s-bbrackett » Mon Apr 23, 2018 10:47 am
Excuse my beginner questions but how to I work the DTS and RTS? I have a RTS function in visual studios but I'm not sure how it works in Micropython.
s-bbrackett
Postby s-bbrackett » Mon Apr 23, 2018 11:16 am
*DTR
Postby kwagyeman » Mon Apr 23, 2018 11:47 am
After opening the serial port make sure to set the line. I can give you a snippet of Qt C++ code for example. This is one line of code normally.
s-bbrackett
Postby s-bbrackett » Mon Apr 23, 2018 3:06 pm
While I don't need the code for Qt, how do I write the code in micropython?
Postby kwagyeman » Mon Apr 23, 2018 3:52 pm
Nothing has to be done on the cam for this. Just print data.
s-bbrackett
Postby s-bbrackett » Mon Apr 23, 2018 4:34 pm
So no settings, no code? Just save and reset?
Postby kwagyeman » Tue Apr 24, 2018 1:08 am
Hey man, you may wish to try by doing o_o.
s-bbrackett
Postby s-bbrackett » Tue Apr 24, 2018 10:38 am
Hey if you could show me a bit of that Qt code, maybe that might help my issues. A while ago, I sent you a post with the current settings/variables in my VS code. If those could clear anything up, let me know.
Thanks.
s-bbrackett
Postby s-bbrackett » Tue Apr 24, 2018 11:09 am
If you understand C#, let me know and I could send you a bit of my code.
Postby kwagyeman » Wed Apr 25, 2018 2:03 am
Paste it. Use the code tags.
s-bbrackett
Postby s-bbrackett » Wed Apr 25, 2018 10:33 am
Here you go:
using System;
using System.IO.Ports;
using System.ComponentModel;
namespace EyeStuff
    class PortDataReceived
        public static void Main()
            SerialPort mySerialPort = new SerialPort("COM3");
            mySerialPort.BaudRate = 115200;
            mySerialPort.Parity = Parity.None;
            mySerialPort.StopBits = StopBits.One;
            mySerialPort.DataBits = 8;
            mySerialPort.Handshake = Handshake.None;
            mySerialPort.RtsEnable = true;
            mySerialPort.DataReceived += new SerialDataReceivedEventHandler(DataReceivedHandler);
            mySerialPort.Open();
            Console.WriteLine("Press any key to continue...");
            Console.WriteLine();
            Console.ReadKey();
            mySerialPort.Close();
        private static void DataReceivedHandler(object sender, SerialDataReceivedEventArgs e)
            SerialPort sp = (SerialPort)sender;
            string indata = sp.ReadExisting();
            Console.WriteLine("Data Received:");
            Console.Write(indata);
Postby kwagyeman » Thu Apr 26, 2018 3:07 am
Okay, is it working?
s-bbrackett
Postby s-bbrackett » Thu Apr 26, 2018 10:30 am
The code compiles with no errors and it runs it's "Press any key" part, but it never prints out any data. At this point, I really don't know what the problem could be besides that I forgot something. Please let me know if you have any suggestions.
s-bbrackett
Postby s-bbrackett » Thu Apr 26, 2018 6:04 pm
Never mind I got it working. However, I wanted to say thank you for your help with the DTR. I forgot one line of code within my script and when I fixed it, everything worked fine. Thanks again.
Postby kwagyeman » Fri Apr 27, 2018 1:58 am
Great to hear!
s-bbrackett
Postby s-bbrackett » Thu May 03, 2018 11:24 am
Hey I'm back again.
I just wanted to know, if I were to use serial pins to communicate between the two cameras, I would ONLY use pins 4 and 5, right? This is also the simplest way to communicate between the two correct?
Thanks.
Postby kwagyeman » Fri May 04, 2018 12:31 am
Yes, communication is just a serial port between the two devices then. It's full duplex. You can use the struct module to send binary messages and decode them. Or, you can send data as text.
s-bbrackett
Postby s-bbrackett » Fri May 04, 2018 10:39 am
So I can just use the print function to send text, and then create a statemachine on the other end to receive it?
s-bbrackett
Postby s-bbrackett » Fri May 04, 2018 10:44 am
I guess the better way to phrase it would be, what's the easiest way to receive data sent by the print command.
Postby kwagyeman » Fri May 04, 2018 11:14 am
No, use this:
from pyb import UART
# Always pass UART 3 for the UART number for your OpenMV Cam.
# The second argument is the UART baud rate. For a more advanced UART control
# example see the BLE-Shield driver.
uart = UART(3, 19200, timeout_char = 1000)
uart.write("Hello World!\r")
time.sleep(1000)
uart.write() accepts any formatted string. So, you can use python string formatting there. See all the uart methods: http://docs.openmv.io/library/pyb.UART. ... light=uart
s-bbrackett
Postby s-bbrackett » Fri May 04, 2018 11:26 am
Awesome! So if that sends strings, how to I receive the strings? Also, don't need to declare the pins anywhere, correct?
Postby kwagyeman » Sat May 05, 2018 2:34 pm
UART(3) is fixed to the same I/O pins.
As for receiving data. Please read the UART methods. In general, you want to call any() to see how many bytes are available and then read() that many bytes. If you'd like to see a great example... please see the Pixy Emulation UART script.
s-bbrackett
Postby s-bbrackett » Mon May 07, 2018 10:48 am
OK so I understand the code, but can I give you an example of how my physical pin system is set up? My system has two openMV cams both plugged into the computer via micro-USB cords. The two cams are then connected with two wires vis pins 4 and 5. Lastly, the camera that sends eye data is disconnected from the openMv IDE while the other is connected. Does this all sound about right?
Thanks again.
Postby kwagyeman » Mon May 07, 2018 11:11 pm
Yes, make sure both cameras share grounds and that RX plugs into TX of the other camera and TX plugs into RX of the other camera.
s-bbrackett
Postby s-bbrackett » Tue May 08, 2018 10:42 am
Thank you, now I have this code as a start but I know its wrong. Could you tell/show me what else I need to add to it.
    inData = uart.any()
    print(inData);
    time.sleep(1000)
Postby kwagyeman » Wed May 09, 2018 1:08 am
    count = uart.any()
    if count:
    	print(uart.read(count))
    	time.sleep(1000)
s-bbrackett
Postby s-bbrackett » Wed May 09, 2018 10:54 am
Thank you. So, I have everything all connected via pins 4 and 5, and my system has two connecting ground pins. Then I have one of the cameras plugged into the IDE while the other is disconnected. However, I still am not reading any data on my receiving camera. Do you have any ideas of what could be wrong?
Postby kwagyeman » Wed May 09, 2018 11:55 am
The code only prints to the IDE. If you want to send data over the UART you have to call the usrt.write() method. Print sends data back to the PC over USB.
s-bbrackett
Postby s-bbrackett » Wed May 09, 2018 12:46 pm
So I replace all the example code you gave me with usrt?
s-bbrackett
Postby s-bbrackett » Wed May 09, 2018 1:43 pm
If you want I can send you examples of my sending code. The code that's receiving the data is the code that you provided for me.
Postby kwagyeman » Wed May 09, 2018 10:21 pm
Okay, I'll take a look.
s-bbrackett
Postby s-bbrackett » Thu May 10, 2018 10:37 am
So for my sending code I have,
uart = pyb.UART(3, 115200)
while (True):
    # Capture snapshot
    # Find eyes !
    eyes = img.find_features(eyes_cascade, threshold=0.5, scale=1.5)
    # Find iris
    for e in eyes:
        iris = img.find_eye(e)
        img.draw_rectangle(e)
        img.draw_cross(iris[0], iris[1])
        uart.write("!EYE x:%d, y:%d, w:%d, h:%d" % e)
        uart.write("!IRIS x:%d, y:%d" % iris)
Then for my receiving code I have
#LED
blue_led = LED(3)
    count = uart.any()
    if count:
        blue_led.on()
        time.sleep(1000)
The pins are then setup as I described before.
s-bbrackett
Postby s-bbrackett » Thu May 10, 2018 4:32 pm
Never mind I got it working. However, I was wondering if you could tell me how to pull a string out of a string. MY data is currently being transmitted in the format of
I want to have just the x and y data values at the end, and I am curious as how to go about it. Thank you.
Postby kwagyeman » Thu May 10, 2018 4:52 pm
Hi, that would be a general purpose python question. You should Google about how to do that in Python and there's likely a lot of examples.
jiapei100
Contact:
Postby jiapei100 » Wed Sep 12, 2018 1:27 pm
Are you using VSCode to debug OpenMV code?
Welcome to Longer Vision
http://www.longervision.ca
