Shape Detection
lucafelici
Shape Detection
Postby lucafelici » Wed Jan 18, 2017 11:47 am
will the new cam m7 be able to do shape detection?
Re: Shape Detection
Postby kwagyeman » Wed Jan 18, 2017 12:38 pm
Hi, what kind of shape detection do you want to do? find_blobs() gives you an area and pixels that match the color settings in that area. This can be used to distinguish between circles and squares. However, I'm assuming you want something else right?
lucafelici
Re: Shape Detection
Postby lucafelici » Thu Jan 19, 2017 2:27 am
yes, I have to recognize shares without color. Triangles, circles and squares
Re: Shape Detection
Postby kwagyeman » Thu Jan 19, 2017 11:00 am
Okay, well, find_blobs() again can be used for this task using just grayscale. The ratio between the area of the bounding box around the object and the number of pixels tracked in the object is different for rectangles, circles, and squares.
However, what's the vision setup for your problem? Are you looking at objects straight on, at angles? With different lighting? Please give me a detailed picture of your problem and what you want to do. You've given two responses now with a low amount of info so I can't really help you if you don't know exactly what you want to do.
lucafelici
Re: Shape Detection
Postby lucafelici » Thu Jan 19, 2017 3:17 pm
I have to recognize a triangle painted on a surface and state where it is relative to the center of the screen and the angle of rotation.
I have to detect a particuoar triangle with angles defined.. for example 45 45 and 90 degrees
Re: Shape Detection
Postby kwagyeman » Sat Jan 21, 2017 10:39 am
Sorry, I forgot about this post for a while.
Okay, so, find_blobs() will work for this. First, you setup the thresholds to find the color of the triangle. This will let you find all the triangles in the image. find_blobs() will tell you the centroid of the object. So, that's the location. find_blobs() will also tell you the rotation of the object too assuming that it has an interesting enough shape for the rotation to be uniquely determined. If all the sides of the triangle are not equal then this should be the case.
Lastly, if you have other objects in the view... the ratio between the bounding rectangle around the triangle and the number of pixels tracked should be equal to:
pixels*2 = area of rect.
So, you'd filter out all blobs find_blobs() returns that aren't close to that ratio between the number of pixels tracked and the area. Where the definition of "close" is some tolerance you have to determine through testing.
lucafelici
Re: Shape Detection
Postby lucafelici » Sat Jan 21, 2017 2:51 pm
Thank you so much for your reply.
I assume I mandato need to search for colors
I don't know if my situation will allow me to do that as the light will change so much
Anyway as sono as I will get my new cam M7 I will try.
Thank you
Luca
prasap1
Re: Shape Detection
Postby prasap1 » Mon Dec 31, 2018 9:21 am
Dear Sir
I am taken rectangular detection examples, it's also working fine but it's detecting all rectangles I want to detect only middle rectangle means what I want to do.
Example: one paper total 8 rectangles are there I want to detect 4th one means what I want to do.
and
Regards
Prasath
Re: Shape Detection
Postby kwagyeman » Mon Dec 31, 2018 11:49 am
Hi, you need to write code in python to filter the object output. This is very application specific so it's up to you.
prasap1
Re: Shape Detection
Postby prasap1 » Wed Jan 02, 2019 3:25 am
Dear Sir
Can you give the small example code for how to filter the object output, I will pickup after that.
Thanks in advance
Regards
Prasath
Re: Shape Detection
Postby kwagyeman » Wed Jan 02, 2019 11:22 am
prasap1
Re: Shape Detection
Postby prasap1 » Mon Jan 07, 2019 2:11 am
See this example: https://github.com/openmv/openmv/blob/m ... on.py#L267
Dear Sir
Can you please send me the rectangles output filter example. Kindly do needful
Re: Shape Detection
Postby kwagyeman » Mon Jan 07, 2019 2:55 am
Hi, if the rectangles are in a row in the x direction you just need to sort the rectangle objects by their x positions and then pick the 4th one from the list if it exist.
You can use the sorted() method in MicroPython to sort the list and you can set the key for sorting to be equal to the x value of each rectangle.
For example:
rect_list = find_rects(...)
sorted(rect_list, key = lambda rect: rect.x())
if len(rect_list) > 3:
  fourth_rect = rect_list[3]
prasap1
Re: Shape Detection
Postby prasap1 » Sat Jan 12, 2019 2:03 am
For example:
Dear Sir
Please find below images for your reference, I want to detect that 6 rectangle's presence. In that if anything missing means pin 1 have to on. After that I will control my process by using pin 1 voltage. Can you please send me the code for that.
Best regards
Prasath
Re: Shape Detection
Postby kwagyeman » Sat Jan 12, 2019 12:44 pm
Do something like this:
import sensor, image, time
thresholds = [(30, 100, 15, 127, 15, 127)]
pin1 = Pin('P1', Pin.OUT_PP, Pin.PULL_NONE)
    blobs = img.find_blobs(thresholds, pixels_threshold=200, area_threshold=200, merge=True)
    for b in blobs:
        img.draw_rectangle(b.rect())
        img.draw_cross(b.cx(), b.cy())
    pin1.value(len(blobs) == 6)
You can use the Tools -> Machine Vision -> Threshold Editor to pick the color thresholds.
prasap1
Re: Shape Detection
Postby prasap1 » Mon Jan 21, 2019 11:09 am
    for b in blobs:
Dear sir
Some what i did like this based on your inputs. This is working now, but want to know that i am doing right method?
from pyb import Pin
sensor.set_pixformat(sensor.RGB565) # grayscale is faster (160x120 max on OpenMV-M7)
pin1 = Pin('P1', Pin.OUT_PP, Pin.PULL_DOWN)
pin1.value(0)
    rect = img.find_rects(threshold = 10000)
    for r in rect:
        img.draw_rectangle(r.rect(), color = (255, 0, 0))
        for p in r.corners(): img.draw_circle(p[0], p[1], 5, color = (0, 255, 0))
        pin1.value(len(rect) == 6)
        print(r)
    print("FPS %f" % clock.fps())
Re: Shape Detection
Postby kwagyeman » Mon Jan 21, 2019 3:36 pm
Move setting the pin outside of the loop. Otherwise the code is only executed if something is found and not if something is not found.
prasap1
Re: Shape Detection
Postby prasap1 » Thu Jan 24, 2019 1:32 am
Sorry sir I am not understand, can you explain briefly.
Thanks for your supports
Re: Shape Detection
Postby kwagyeman » Thu Jan 24, 2019 1:33 am
Move the pin1.value() statement outside of the for loop.
prasap1
Re: Shape Detection
Postby prasap1 » Fri Apr 12, 2019 4:26 am
I am doing shape detection by using OpenMV cam, after shape detection pin1 value will change 0 to 1 but I am getting only 1.2V from pin1. voltage drop is happening. what can I do for that.
I checked voltage value in pin1 its coming 3.2V but after jointed 2 feet length wire voltage drop is happening its showing 1.2V only what can I do for that. can you please help me.
Thanks in advance.
Re: Shape Detection
Postby kwagyeman » Fri Apr 12, 2019 12:16 pm
Oh, yeah, you have to use an amplifier to cover that distance. E.g. use something like this:
https://www.sparkfun.com/products/12009
You can use a higher voltage on the other side to go farther.
prasap1
Re: Shape Detection
Postby prasap1 » Sat Apr 13, 2019 11:15 pm
I am using only 1 meter wire, for that also I have use amplifier for get 3V?.
Re: Shape Detection
Postby kwagyeman » Sun Apr 14, 2019 12:06 am
Hi, your wire shouldn't have such a voltage drop. Check your wire resistance. It should be less than 1 ohm.
prasap1
Re: Shape Detection
Postby prasap1 » Sat Apr 20, 2019 5:47 am
I ordered what you recommended, how can I use this.
After detecting the shape in openmv cam p1 will get energy's.
So I'll get 3.3V from openmv cam. Where I want to connect positive and negative wire in amplifier which you recommended.
Thanks in advance
Re: Shape Detection
Postby kwagyeman » Sat Apr 20, 2019 5:14 pm
What is the load at the end of the wire? If it's a relay you need to use a transistor driver to drive the relay.
https://www.electronics-tutorials.ws/bl ... rcuit.html
mbattle2072
Re: Shape Detection
Postby mbattle2072 » Mon Jun 10, 2019 5:19 pm
Would you happen to have a similar shape detection algorithm for C++??
please and thanks in advance!!
Re: Shape Detection
Postby kwagyeman » Mon Jun 10, 2019 9:03 pm
No, not really.
