Import data on matlab
GiusB
Postby GiusB » Mon Jan 13, 2020 4:35 am
I wrote a program that allows me to identify the yellow color and see the position of the center of the box (surrounding it) in real time.
I can read the coordinates of the center in pixels from the terminal,
is it possible to pass these values on matlab/simulink directly?
Thank you!
Re: Import data on matlab
Postby iabdalkader » Mon Jan 13, 2020 10:40 am
I don't have much experience with matlab, but if you can open a serial port in matlab you should be able to read those values, also try searching the forums you should find some posts about matlab and openmv.
GiusB
Postby GiusB » Tue Jan 14, 2020 4:31 am
Otherwise is it possible to connect the camera with an arduino system and process this data?
Postby iabdalkader » Tue Jan 14, 2020 6:19 am
Yes, see the Arduino examples in the IDE menu.
