Apriltag and accurate rotation measurement
batu
Postby batu » Thu Oct 10, 2019 4:23 am
Apriltag tag25_09 is used for rotation measurement. I have tag size constraint. Can't use tag size bigger than 6cm.
So rotation angles are quite fluctuate and noisy.
How can I improve the rotation angle accuracy in such situation?
Re: Apriltag and accurate rotation measurement
Postby kwagyeman » Thu Oct 10, 2019 11:11 am
You should filter the rotation angle input. After detecting a tag once you should be able to track it and filter the rotation angle by expecting movement to follow a certain profile.
Also, increase the camera exposure and decrease AGC, this makes the image more stable.
batu
Postby batu » Fri Oct 11, 2019 1:07 am
Thanks for the reply.
Say the expected rotation angle is 20deg.
But it is varying in quite wide range.
So you mean I need to take most frequent data?
Postby kwagyeman » Fri Oct 11, 2019 1:52 am
What the quality of the lock? Like, how many pixels can it see. The algorithm needs a lot of pixels of the tag for a good measurement.
batu
Postby batu » Tue Oct 15, 2019 5:24 am
yeah you are right. When the distance is far a lot fluctuation and get closer, quite ok.
Postby kwagyeman » Tue Oct 15, 2019 2:55 pm
We have a new camera with dram coming soon that can do VGA AprilTags and above. The frame rate isn't high but it works.
Users browsing this forum: No registered users and 8 guests
