Connectivity issues
Melan
Connectivity issues
Postby Melan » Tue Aug 06, 2019 9:12 am
Hello, I encountered such a problem. I received a board with a damaged lens, I replaced it with another one, since I ordered several lenses. When connected via usb, the scripts from the examples do not start, and the LED flashes white. At the same time, such an error is written in the device’s memory, FATAL ERROR: Failed to init sensor, error: -2. Please help with this problem.
Re: Connectivity issues
Postby kwagyeman » Tue Aug 06, 2019 1:31 pm
Hi, the unit is damaged. Can you email us with the receipt of where you bought it from?
Postby iabdalkader » Tue Aug 06, 2019 8:51 pm
Did it work before replacing the lens ? And did you remove the sensor from the camera or just replace the lens without removing the sensor ? If you removed the sensor, make sure it's making full contact.
Melan
Postby Melan » Wed Aug 07, 2019 2:55 pm
I bought it in your srtore 3 weeks ago.
Melan
Postby Melan » Wed Aug 07, 2019 2:56 pm
I just replaced the lens, and didnt work with lens that was damaged
Postby iabdalkader » Wed Aug 07, 2019 3:32 pm
Just to be clear, when you received the camera it was Not working ? And what do you mean by damaged ? Can you send us some photos of the lens and camera to openmv@openmv.io
Melan
Postby Melan » Tue Aug 13, 2019 4:02 am
Yes, it was not working, lens was squashed and probably lens damaged the module under the lens. I sent the photo to openmv@openmv.io.
Postby kwagyeman » Wed Aug 14, 2019 11:56 am
Hi, I didn't get an email yet.
Melan
Postby Melan » Thu Aug 15, 2019 2:21 am
I sent again from email nppuniversal@gmail.com
Postby kwagyeman » Thu Aug 15, 2019 12:17 pm
Got it.
Melan
Postby Melan » Fri Aug 16, 2019 2:27 am
Got it.
Thank you for help
