Power supplied of Openmv4 H7 with TOF module
jll
Postby jll » Wed Jul 10, 2019 8:45 am
I use Openmv4 with TOF module on the unmanned aerial vehicle,but openmv sometimes shut down. The main.py works fine when not on the fly.
So I suspect that the Power is limitted when on the UAV.
I wonder How much current i need supply to make it work well with TOF(U=4.5V to 5V).
The China Store says about 200mA to 500mA.I am not very sure
Re: Power supplied of Openmv4 H7 with TOF module
Postby kwagyeman » Wed Jul 10, 2019 11:20 am
Um, the OpenMV Cam needs about 200 mA. How is the system and the ToF unit powered? You could use a second battery which may ease the problem.
Postby iabdalkader » Wed Jul 10, 2019 5:48 pm
Can you share a link to the TOF module ?
jll
Postby jll » Wed Jul 10, 2019 9:02 pm
https://singtown.com/product/50448/open ... ce-shield/
thanks,this is the link
kidswong999
Postby kidswong999 » Fri Jul 12, 2019 9:15 am
Hi, just post on https://forum.singtown.com/category/5/openmv-cam
Please paste all codes, and I will test.
You could also contact customer service on taobao.
By the way, the distance shield is so low-power, it is under 20ma.
jll
Postby jll » Sat Jul 13, 2019 4:24 am
Chinese Openmv Store on taobao just know nothing but want money. Customer service is bad.
jll
Postby jll » Sat Jul 13, 2019 4:35 am
I use the demo distance program in the IDE,if you can test it ,i will be very
grateful
kidswong999
Postby kidswong999 » Tue Jul 16, 2019 8:21 am
If you have technical questions, just goto https://forum.singtown.com, I answer questions every day, I will test and answer it.
If you think goods have quality issues, just replace it or refund.
I am not the technical support here, I am only responsible for the China region.
And I will not answer you here. Although this distance shield was developed by me.
jll
Postby jll » Tue Jul 16, 2019 9:52 pm
shamed on you
kidswong999
Postby kidswong999 » Tue Jul 16, 2019 11:28 pm
If you buy a genuine board, you will certainly get a genuine service, and vice versa.
If it is genuine, just contact the seller, the problem can be solved directly. It is impossible to run an error in the example.
