Detecting Letters
finnleh
Detecting Letters
Postby finnleh » Sun Apr 14, 2019 12:17 am
Hello! I am getting my OpenMV H7 on Monday, and I am trying to learn about the camera already, so I can prepare some code and try some things with the camera this week.
One thing I did not find is if it is possible, to detect Letters with the OpenMV H7. If yes, how would that work?
Thank you,
Finn :)
Re: Detecting Letters
Postby kwagyeman » Sun Apr 14, 2019 12:44 am
Yep, I'll have the IDE release out that enables this over the weekend. Just see the chars74K example. Under the CMSIS-NN stuff.
Note, we are working on porting Tensor Flow mobile to the OpenMV Cam which will be replacing our current frame work.
finnleh
Postby finnleh » Sun Apr 14, 2019 8:36 pm
Hey! Thank you for the link :)
If I just want certain characters to be seen, and not every single character, how would the code need to be modified? I can't test it right now, that is why I am asking. Also, the camera will probably not arrive before Thursday...so if you could provide me with some coding help for the camera, I would be really happy :)
And if I have the camera scanning these certain letters, how can I tell my Arduino Mega that there is a letter and it now has to perform an action, relating to this certain letter?
Thank you, Finn :)
Postby kwagyeman » Sun Apr 14, 2019 9:01 pm
Hi, it just classifies characters. It's a network. So, it assumes there's a character in front of it. There's no modifying the code. you have to re-train the net to do something else. A trival character check is to look for straight lines and check how many you see.
finnleh
Postby finnleh » Sun Apr 14, 2019 9:08 pm
Ok. So how would it work, if I want the camera to look for letters, and if there is no letter, it just does nothing. But if there is a letter (one of the letters I want to see), it sees which one and sends some kind of notification to the Arduino Mega so that the Arduino executes a certain function, according to the letter seen?
Thank you,
Finn
Postby kwagyeman » Sun Apr 14, 2019 9:14 pm
I'd just use the line segment detector to find a cluster of lines and then use the network on the location where the lines are to classify the letter. This would be a very small change to the base code provided.
We will also be offering TensorFlow soon where you can train a network yourself using more modern tools than Caffe.
finnleh
Postby finnleh » Sun Apr 14, 2019 10:01 pm
Ok, let's say, I wanted to modify this code, so it compares the lines to the three letters. Let's say, we want to detect A, as an example.
# Find Line Segments Example
# This example shows off how to find line segments in the image. For each line object
# found in the image a line object is returned which includes the line's rotation.
# find_line_segments() finds finite length lines (but is slow).
# Use find_line_segments() to find non-infinite lines (and is fast).
enable_lens_corr = False # turn on for straighter lines...
import sensor, image, time
sensor.set_pixformat(sensor.RGB565) # grayscale is faster
# All lines also have `x1()`, `y1()`, `x2()`, and `y2()` methods to get their end-points
# and a `line()` method to get all the above as one 4 value tuple for `draw_line()`.
    if enable_lens_corr: img.lens_corr(1.8) # for 2.8mm lens...
    # `merge_distance` controls the merging of nearby lines. At 0 (the default), no
    # merging is done. At 1, any line 1 pixel away from another is merged... and so
    # on as you increase this value. You may wish to merge lines as line segment
    # detection produces a lot of line segment results.
    # `max_theta_diff` controls the maximum amount of rotation difference between
    # any two lines about to be merged. The default setting allows for 15 degrees.
    for l in img.find_line_segments(merge_distance = 0, max_theta_diff = 5):
        img.draw_line(l.line(), color = (255, 0, 0))
        print(l)
    print("FPS %f" % clock.fps())
How would I find out, that the lines detected are equal to the lines of the letter A? Is there some kind of library, that I could use?
Thank you, Finn
Postby kwagyeman » Sun Apr 14, 2019 10:26 pm
Hi, the CNN running on the H7 does that. All the lines do will tell you where the character is.
Please wait till the next OpenMV IDE release. We will have the net for you then. I've finished the windows builds. Doing the Linux ones now.
finnleh
Postby finnleh » Sun Apr 14, 2019 10:58 pm
When will that new IDE be released? And what is that CNN you are talking about? Sorry, I am new to OpenMV :roll:
Postby kwagyeman » Sun Apr 14, 2019 11:12 pm
Hi, the video with me detecting characters - chars74k. I'm working on the IDE release. OpenMV isn't like a big company. Asking me questions literally delays the IDE release ;) - because I'm the one doing it.
Um, if you are using windows I can give you the windows IDE link. I've already built it and published it to our staging server.
Postby kwagyeman » Mon Apr 15, 2019 12:58 am
I've finished building windows/mac/linux32/linux64. I just need to fix an issue with raspberryPi which I will do tomorrow.
finnleh
Postby finnleh » Mon Apr 15, 2019 7:40 am
If you could send me the link, that would be awesome :)
finnleh
Postby finnleh » Mon Apr 15, 2019 10:35 am
Oh, and I have another short question: Is there a proper and detailed documentation on how to connect the camera to the arduino board, and how to write the arduino code according to what the camera sees?
Thank you for all your help,
Finn
Postby kwagyeman » Mon Apr 15, 2019 1:20 pm
Hi, the point of the OpenMV Cam is to not use an Arduino. It can do quite a bit of board I/O control itself. Anyway, in the examples folder there are examples showing how to connect an Arduino.
Which IDE version do you want? Windows, Mac, Linux?
finnleh
Postby finnleh » Mon Apr 15, 2019 4:09 pm
Windows, please. Thank you!
Postby kwagyeman » Mon Apr 15, 2019 5:37 pm
http://upload.openmv.io/openmv-ide-wind ... -2.2.0.exe
See the ML examples, chars74K, then use the Tools->Machine Vision->Model Explorer to copy the model over.
finnleh
Postby finnleh » Mon Apr 15, 2019 6:41 pm
Thank you for the link, but I can't install the new version. There is an error, that says: "Windows cannot access the specified device, path or file. You may not have the appropriate permission to access the item."
Is it something I do wrong, or an error with that file?
akib.rhast
Postby akib.rhast » Mon Apr 15, 2019 7:08 pm
Came here to look for an update regarding the raspi. Found this. Thanks!!
Postby kwagyeman » Mon Apr 15, 2019 7:33 pm
Installs fine on 3 PCs I tested... where does the error happen?
Also, please always post with like context on what an error is. I get enough help support emails now where might start ignoring folks.
finnleh
Postby finnleh » Mon Apr 15, 2019 8:51 pm
Sorry, my bad. My anti virus application was it, that caused the problem x)
finnleh
Postby finnleh » Mon Apr 15, 2019 8:57 pm
Where should the Model Explorer be? I don't find it in Tools -> Machine Vision.
Postby kwagyeman » Mon Apr 15, 2019 9:15 pm
The CNN library, copy the model to your SD card for the camera.
Postby kwagyeman » Tue Apr 16, 2019 12:19 am
Okay, releasing the IDE now. The raspberry pi build works.
This is the official OpenMV Cam H7 release!
finnleh
Postby finnleh » Tue Apr 16, 2019 11:25 pm
Hello! My camera finally arrived, so I got to test a few things. I came to the conclusion, that using the templates might be an easy way to detect letters. Do you think, using templates is a reliable way to detect letters? Or how would you do it?
When I tested it with the printed letters, it worked. But only at a certain range...so if I was too far away or too close, it wouldn't work...
This is the code. It is basically one of the examples, just a bit modified.
import time, sensor, image
from pyb import UART
ser = UART(3,115200,timeout_char=1000)
# Reset sensor
# Set sensor settings
sensor.set_contrast(1)
sensor.set_gainceiling(16)
# Max resolution for template matching with SEARCH_EX is QQVGA
sensor.set_framesize(sensor.QQCIF)
# You can set windowing to reduce the search image.
#sensor.set_windowing(((640-80)//2, (480-60)//2, 80, 60))
# Load template.
# Template should be a small (eg. 32x32 pixels) grayscale image.
template1 = image.Image("/H_Letter.pgm")
template2 = image.Image("/U_Letter.pgm")
template3 = image.Image("/S_Letter.pgm")
# Run template matching
while (True):
    # find_template(template, threshold, [roi, step, search])
    # ROI: The region of interest tuple (x, y, w, h).
    # Step: The loop step used (y+=step, x+=step) use a bigger step to make it faster.
    # Search is either image.SEARCH_EX for exhaustive search or image.SEARCH_DS for diamond search
    # Note1: ROI has to be smaller than the image and bigger than the template.
    # Note2: In diamond search, step and ROI are both ignored.
    harmed = img.find_template(template1, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
    unharmed = img.find_template(template2, 0.70, step=4, search=SEARCH_EX)
    stable = img.find_template(template3, 0.70, step=4, search=SEARCH_EX)
    if harmed:
        img.draw_rectangle(harmed,5)
        ser.write(0x01)            #Error: TypeError: Object with buffer protocol required.
        print("Detected H")
    if unharmed:
        img.draw_rectangle(unharmed,5)
        ser.write(0x02)            # same Error
        print("Detected U")
    if stable:
        img.draw_rectangle(stable,5)
        ser.write(0x03)            # same Error
        print("Detected S")
    #if l:
    #  img.draw_rectangle(l,5)
    #  ser.write(0x02)
As you see, I get an error at ser.write(...). Is that error, because I have no Arduino connected? Or what does this error mean? If I comment those lines, everything works fine.
Thank you for your help,
Finn :)
Postby kwagyeman » Wed Apr 17, 2019 1:21 am
Hi, write() doesn't take a number, it takes a string. If you want to send the byte value 0x03 then do write(str(0x3)) or like write("\x03"), etc.
Template matching is not scale or rotation invariant. So, by definition it doesn't work when scale (zoom) or the image is rotated. It is translation invariant however.
Template matching is fine as long as you just need to find the x/y translation. It's no good for scale/zoom issues. That said, the CNN will struggle with the same issues as it's not trained on rotated and scaled data.
finnleh
Postby finnleh » Wed Apr 17, 2019 3:14 pm
Is it possible, to use the CNN Chars74K, only when there is actually a letter? For example, if there is only a white wall, it just gives nothing. Oh, and I tried the Chars74K network library on printed letters, but it gave me nothing. Also, the camera was just black and white. It gave me B or P, even though the letters were completely different, S or U for example. They don't look like P or B, not even close to P or B. If I change the contrast, so that it is not just completely black or white, would that change the detection of letters? Or does it always detect wrong letters, no matter what way I do it?
Thank you, Finn :)
finnleh
Postby finnleh » Wed Apr 17, 2019 3:20 pm
I think, I solved the problem, that it always detects the wrong letter. But I still don't know, how I can make it detect letters, only if there is actually something. What, if I tell him, to only start the detection procedure, when there is something black?
finnleh
Postby finnleh » Wed Apr 17, 2019 3:33 pm
And just one more question: Where do I find the '/img-chars74k.network'? Or does the '/fnt-chars74k.network' work better for printed letters?
Postby kwagyeman » Wed Apr 17, 2019 3:37 pm
Um, so, there are 3 different networks for the character 74k. Only the fnt one works. The one trained on image letters just overfits and doesn't work in real life.
To make it work better I'm pretty sure it would require edge detection first (using canny) versus the raw image data. This is because the general image one is full of characters of different resolutions, sizes, rotations, etc. So the net learns how to cheat the dataset instead of what is in the image because there are too many artifacts.
finnleh
Postby finnleh » Wed Apr 17, 2019 3:42 pm
Ok, and how would that work? How would the code look like?
Postby kwagyeman » Wed Apr 17, 2019 4:01 pm
Um, try out the Color Tracking -> Single Color Greyscale tracking script. Adjust the thresholds to find the white character.
Once you do that, you can print out the blob.rect() to see where the blob is. Then you pass the blob.rect() (if found) to the nn.forward(roi=blob.rect()).
That said the rect may be too small so you might want to temporarily create a new rect object that's slightly bigger than the blob rect. For an example of doing this see the AprilTag Examples -> higher resolution AprilTag example.
finnleh
Postby finnleh » Wed Apr 17, 2019 4:56 pm
Alright...
This is the code, I have so far:
# Color Tracking Thresholds (Grayscale Min, Grayscale Max)
# The below grayscale threshold is set to only find extremely bright white areas.
thresholds = (0, 40)
blobby = False
sensor.set_pixformat(sensor.GRAYSCALE) # Set pixel format to GRAYSCALE
sensor.set_windowing((96, 96))       # Set 128x128 window.
sensor.skip_frames(time=500)
sensor.set_auto_gain(False)
sensor.set_auto_exposure(False)
# Load chars74 network
net = nn.load('/fnt-chars74k.network') # works on printed font
# net = nn.load('/fnt-chars74k.network') # works on handwritten chars
# net = nn.load('/img-chars74k.network') # works on images of chars
labels = ['n/a', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9']
for i in range(ord('A'), ord('Z') + 1): labels.append(chr(i))
for i in range(ord('a'), ord('z') + 1): labels.append(chr(i))
    clock.tick()                    # Update the FPS clock.
    #imgBlob = sensor.snapshot()     # Picture of blob, to see the letter
    # Adjust the binary thresholds below if things aren't working - make sure characters are good.
    #img.find_edges(image.EDGE_CANNY, threshold=(100, 100))
    for blob in img.find_blobs([thresholds], pixels_threshold=100, area_threshold=100, merge=True):
        if blob.elongation() > 0.5:
            img.draw_edges(blob.min_corners(), color=0)
            img.draw_line(blob.major_axis_line(), color=0)
            img.draw_line(blob.minor_axis_line(), color=0)
        img.draw_rectangle(blob.rect(), color=127)
        img.draw_cross(blob.cx(), blob.cy(), color=127)
        blobby = True
        img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=40, color=127)
    if (blobby == True):
        out = net.forward(img.binary([(100, 255)]), softmax=True)
        max_idx = out.index(max(out))
        score = int(out[max_idx]*100)
        if (score < 50):
            score_str = "??:??%"
            score_str = "%s:%d%% "%(labels[max_idx], score)
        img.draw_string(0, 0, score_str, color=(0, 255, 0))
        print(score_str)
        blobbi = False
    print(clock.fps())             # Note: OpenMV Cam runs about half as fast when connected
If I execute this code, it will search for blobs. As soon as it finds one, the image will change to binary (black&white) and look for the letter. But it looks for the letter in the whole image, not just where the blob is. Also, it will stay in this binary mode (how can I exit this binary mode, and go back to normal grayscale?). Another problem is, that it will detect blobs anywhere, but I think that is solvable with the threshold.
So, my questions are: How do I exit the binary image mode? How do I change the image size to the size of the blob, or let the camera only search for letters within the blob rectangle?
Thank you for your help ^^
Postby kwagyeman » Thu Apr 18, 2019 1:49 am
Blob detection works in binary mode too. So, I'd just do everything in that mode. I.e. binary the image first using color thresholds. Then find_blobs() just looks for "white" in the binary image.
Do:
net.forward(img.binary([(100, 255)]), softmax=True, roi=blob.rect())
Or:
# Next we look for a tag in an ROI that's bigger than the blob.
w = min(max(int(blob.w() * 1.2), 10), 160) # Not too small, not too big.
h = min(max(int(blob.h() * 1.2), 10), 160) # Not too small, not too big.
x = min(max(int(blob.x() + (blob.w()/4) - (w * 0.1)), 0), img.width()-1)
y = min(max(int(blob.y() + (blob.h()/4) - (h * 0.1)), 0), img.height()-1)
net.forward(img.binary([(100, 255)]), softmax=True, roi=(x, y, w, h))
finnleh
Postby finnleh » Fri Apr 19, 2019 2:23 pm
Can the board work without the laptop, too? If I connect it to my arduino board, but disconnect it from my laptop, how would I ensure, that the code is on my camera and that the camera is turned on and does whatever the code wants it to do?
Postby kwagyeman » Fri Apr 19, 2019 6:21 pm
Tools->Save Script to OpenMV Cam
Tools->Reset OpenMV Cam
finnleh
Postby finnleh » Sat Apr 20, 2019 1:45 pm
Ok. So now the code is saved on my camera. But how do I start the code from outside the IDE? Is there a way through arduino coding? Or some kind o button or connection,that has to be turned on?
finnleh
Postby finnleh » Sat Apr 20, 2019 1:54 pm
Or does it always automatically execute the main.py file, when connected correctly?
Postby kwagyeman » Sat Apr 20, 2019 5:11 pm
When the system is powered on it starts running main.py.
