UART communication with Teensy (Arduino)
hcrobo
Postby hcrobo » Mon Apr 01, 2019 4:58 am
Hi all,
im trying to send over blob.cx() using colour tracking but the communication doesn't seem to work and the Teensy side doesn't read any receiving bytes on Serial.available
Here is my OpenMV M7 code:
import sensor, image, time, math,struct
from pyb import UART
# Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max), declare variables
bluethresh = [(8, 35, -19, 25, -50, 20)] #to set pre-match
yellowthresh = [(54, 95, -10, 20, 20, 57)]
goalthresh = 0
goalX = 0
blueX = 0
yellowX = 0
goalcolour = 0
uart = UART(3, 115200, timeout_char=100) #(only UART 1 or 3 available,baud rate,delay b/w frames)
uart.init(115200, bits=8, parity=None, stop=1, timeout_char=10)
print("Waiting for Arduino...")
sensor.set_framesize(sensor.QQVGA) #for 160x120 resolution
sensor.set_auto_exposure(3, 8750)
img=sensor.snapshot()
for blob in img.find_blobs(yellowthresh, pixels_threshold=700, area_threshold=200):
    yellowX = blob.cx()
for blob in img.find_blobs(bluethresh, pixels_threshold=700, area_threshold=200):
    blueX = blob.cx()
if yellowX > blueX: #test for which goal it is facing
    goalthresh = yellowthresh
    goalcolour = 1
    goalthresh = bluethresh
    goalcolour = 2
    for blob in img.find_blobs(goalthresh, pixels_threshold=600, area_threshold=200, merge=True): #change area threshold in case localisation marks fail
        goalX = blob.cx()
        uart.write(struct.pack("<b",goalX))
        print(goalX)
        print("sent")
    except OSError as error:
        pyb.LED(1).on()
        pyb.LED(2).off()
        pyb.LED(3).off()
        print(error)
        time.sleep(3000)
and this is my Arduino code:
  void setup() {
  Serial.begin(9600);
  Serial2.begin(115200);
void loop() {
  int goalX=0;
  while(Serial2.available()<1);
    goalX=Serial2.read();
    Serial.print(goalX);
    Serial.print(" ");
    Serial.println();
Any help would be appreciated, thank you!
Re: UART communication with Teensy (Arduino)
Postby kwagyeman » Mon Apr 01, 2019 11:04 am
Hi, I can debug this tonight. It looks pretty right however.
It's probably something really simple.
Postby iabdalkader » Tue Apr 02, 2019 1:03 pm
How do you connect the two boards ? You should connect TX->RX, RX->TX and ground.
