SD Card Problem Migrating to H7
dcolemans
Postby dcolemans » Thu Jan 24, 2019 4:02 pm
Everything works seamlessly pulling the code over to the H7, except... I can Open a file and Add_frames and there is no complaint. Then when I try to Close the file it crashes. Looking later, zero bytes have been written to the video file on SD. This all works neatly on the M7. Anything I should know that's different? Here's a snippet of the code
def openVideo():
    global fileSeq
    fileSeq += 1                #change filename
    if fileSeq > 99: fileSeq = 1
    filename1 = "MvLineFile%i.mp4" % (fileSeq)
    global m
    m = mjpeg.Mjpeg(filename1)  #open next file
    global fileOpen
    fileOpen = True
def closeVideo():
    global m
    m.close(clock.fps())        #make sure file written to sd
    global fileOpen
    fileOpen = False
if fileOpen == True:
    m.add_frame(img)            #capture image with lines and text
Dave
Re: SD Card Problem Migrating to H7
Postby iabdalkader » Thu Jan 24, 2019 4:36 pm
Can you attach the full script ? Also does the example mjpeg.py work ?
Postby kwagyeman » Thu Jan 24, 2019 4:37 pm
Hi, can you give a full sample script that causes the issue? If it works on the M7 and not the H7 then it's a bug. Ibrahim will be able to fix it.
dcolemans
Postby dcolemans » Thu Jan 24, 2019 6:07 pm
Code Follows. Thanks for the quick response Kwabena. It needs to have an Arduino attached to get the BGN or END signal. But maybe you can see how I'm using the SD anyway.
# RedYellowH7Sd -
#94 100 -27 1 20 127
#YELLOW_THRESHOLD = (94, 100, -40, 1, 20, 127)  #Kwabena yellow line
YELLOW_THRESHOLD = (75, 100, -27, 1, 20, 127)  #Kwabena yellow line
#YELLOW_THRESHOLD = (90, 100, -20, 127, 40, 127)  #Dave yellow line
#YELLOW_THRESHOLD = (90, 100, -20, -10, 55, 127)  #Dave yellow line
RED_THRESHOLD = [(50, 65, 40, 80, 15, 127)]   # generic_red_threshold
GLARE_THRESHOLD = (90, 100, -101, 0, 30, 50) #Dave garage
MAG_THRESHOLD = 5
Top_THRESHOLD = 4
RED_SCREEN = (0xFF, 0x00, 0x00)
import sensor, image, time, math, pyb, ustruct, mjpeg
from pyb import UART
uart = UART(3, 115200, timeout_char=2000)
enable_lens_corr = True # turn on for straighter lines...
sensor.set_framesize(sensor.QQVGA)  #160 by 120
#roi_sample = (left,top,right,bottom)
roi_top = (0,0,160,60)
roi_bottom = (20,30,140,110)
sensor.set_vflip(True)
sensor.set_hmirror(True)
#sensor.skip_frames(time = 0)  per4 kwabena
sensor.skip_frames(time = 200)
#sensor.set_auto_gain(True)
sensor.set_auto_gain(False)
sensor.set_auto_whitebal(False) #not the default
fileSeq = 0
fileOpen = False
time = [0]
start = pyb.millis()
carSpeed = 0
workStr = ''
filename1 = "MvLineFile%i.mp4" % (0)
m = ""
def valmap(x, in_min, in_max, out_min, out_max):
    return int((x-in_min) * (out_max-out_min) / (in_max-in_min) + out_min)
def openVideo():
    global fileSeq
    global m
    global fileOpen
    fileOpen = True
def closeVideo():
    global m
    global fileOpen
    fileOpen = False
    img = sensor.snapshot().histeq()
    if enable_lens_corr: img.lens_corr(1.8) # for 2.8mm lens...seems to help
#  first look to see if there's a stop sign in front of us
#  ? use roi to look only at center?
#  ? seems like we dont need area_threshold if target is octagon ..area_threshold=50,
#  ? x/y stride seems like it could apply to us with solid color target
    stopSize = 0  # null value for stop sign
    for blob in img.find_blobs(RED_THRESHOLD, pixels_threshold=25, x_stride=4, y_stride=4, merge=True):
        img.draw_rectangle(blob.rect(),thickness=2)
        img.draw_cross(blob.cx(), blob.cy(),thickness=2)
        print (blob.w())  #width
        stopSize = blob.w()
            #  img.binary([GLARE_THRESHOLD],zero=True) # Chg non yellow to black
    bAngle = 99 #null value for bottom angle
    tAngle = 99 #null value for top angle
    line = img.get_regression([YELLOW_THRESHOLD], roi=roi_bottom, robust=True)
    if line and (line.magnitude() >= MAG_THRESHOLD) and line.y1()<40:
      # good line in bottom roi for steering
        img.draw_line(line.line(),thickness=2, color=(0,127,127))
        if line.y1() > line.y2():  #line is upside down
            bAngle = valmap(line.x2(), 0, 160, -45, 45) # x2 is the top
        else:   #11/24/18 start at 15 to bias tward left
            bAngle = valmap(line.x1(), 0, 160, -45, 45) # angle
    line = img.get_regression([YELLOW_THRESHOLD], roi=roi_top, robust=True)
    if line and (line.magnitude() >= Top_THRESHOLD) :
        #good line in top roi for slowing down speed
        img.draw_line(line.line(), color=(0,127,127),thickness=2)
            tAngle = valmap(line.x2(), 0, 160, -45, 45) # x2 is the top
            tAngle = valmap(line.x1(), 0, 160, -45, 45) # angle
        send_string = "b=%d t=%d s=%d" % (bAngle, tAngle, stopSize)
        # send bottom angle for steering and top angle for look-ahead action
        send_string = "b=%d s=%d" % (bAngle, stopSize)  #only send bottom angle
    uart.write(send_string)
    uart.write("\n")    #send to arduino on serial
    if uart.any() > 0:
        workStr = uart.readline().decode() #read into string
        workStr = workStr[:-2]            # chop off cr lf
        if workStr == 'BGN' and fileOpen == False:  #look for control chars
            openVideo()
            start = pyb.millis()        # start clock over
        elif workStr == 'END' and fileOpen == True:
            closeVideo()
        elif workStr == 'BBB':
            img.draw_string(0, 40, "BRAKES",color = RED_SCREEN, mono_space=False)
            if workStr.isdigit():         #else update carSpeed for display
                carSpeed = int(workStr)
    img.draw_string(0, 0, "ms: %i"%(pyb.elapsed_millis(start)),color = RED_SCREEN,mono_space=False)
    img.draw_string(0, 10, "top: %i"%(tAngle),color = RED_SCREEN,mono_space=False)
    img.draw_string(0, 20, "bot: %i"%(bAngle),color = RED_SCREEN,mono_space=False)
    img.draw_string(0, 30, "spd: %i"%(carSpeed),color = RED_SCREEN,mono_space=False)
    print (clock.fps(), send_string)
Dave
dcolemans
Postby dcolemans » Thu Jan 24, 2019 7:59 pm
I was thinking the problem might stem from the fact that with the H7 I'm doubling the resolution (4x pixels), but I just ran a test on the H7 using the code from the M7 (80x60) and it failed in the same circumstance, i.e. when I tried to close the SD video file.
Dave
Postby iabdalkader » Thu Jan 24, 2019 8:13 pm
Yes I can reproduce the bug with the mjpeg.py example, will debug it and get back to you.
dcolemans
Postby dcolemans » Thu Jan 24, 2019 8:35 pm
I tried the mjpeg.py example and it too fails. It start up with the message, runs for a few seconds (200 frames I assume) and then dies. After that I have to un-power and re-power the cam to get the USB to connect.
Our messages are crossing. OK. Thanks for looking into it. You guys are the greatest!
Dave
dcolemans
Postby dcolemans » Fri Jan 25, 2019 12:32 pm
I don't know if this is relevant, but I tried the H7 recording GIF and it works fine. So maybe it's more of a JPEG issue than an SD one.
Dave
Postby iabdalkader » Sat Jan 26, 2019 1:42 pm
Hi, this is a bug in FatFS exFAT implementation. I enabled exFAT recently because it's faster than FAT, especially when working with large SD cards (> 32GBs), but it seems broken. Your M7 probably works because you don't have that FW that enables exFAT. Anyway, the latest FatFs fixes this issue, but I can't update FatFs now because MP changed it a lot. So I'll just disable exFAT for now, and I created an issue hopefully it will be updated and I'll re-enable exFAT after.
https://github.com/micropython/micropython/issues/4431
dcolemans
Postby dcolemans » Sun Jan 27, 2019 12:43 pm
It sounds like you're saying that I should re-load the firmware in the H7. It there a special version I should use?
Dave
dcolemans
Postby dcolemans » Sun Jan 27, 2019 2:22 pm
I got the firmware post on the "other" forum thread viewtopic.php?f=3&t=1117&p=7163#p7163. I loaded it and it worked perfectly for solving the SD card problem. Thank you.
Dave
Postby iabdalkader » Sun Jan 27, 2019 4:12 pm
Any older release should work, I'll be doing a new release with exFAT disabled soon.
