Quantize network stops at "Network initialization done." step
chrisPyres66
Postby chrisPyres66 » Thu Jan 24, 2019 3:03 am
I trained and i try to quantize the network but it stops at "Network initialization done." step.
The commands is :
python2 nn_quantizer.py --gpu --model models/lettre_O_V1/lettre_O_train_test.prototxt --weights models/lettre_O_V1/lettre_O_iter_1300.caffemodel --save models/lettre_O_V1/lettre_O.pkl
I join the log.txt of the command and lettre_O_train_test.prototxt network achitecture.
lettre_O_iter_1300.caffemodel trained network is too big (40.2Mo).
Help would be great,
files.zip
(3.19 KiB) Downloaded 22 times
Re: Quantize network stops at "Network initialization done." step
Postby kwagyeman » Thu Jan 24, 2019 11:52 am
Hi, that script isn't robust if the network is bad when you trained it. The error is happening before the conversion. What accuracy did you get on training the net and testing it? If they were bogus you cannot convert the network.
Users browsing this forum: Bing [Bot] and 5 guests
