how to change i2c device address (Multi mlx90614 sensors)
Raul_
Postby Raul_ » Tue Jan 22, 2019 4:48 am
Hi, engineers from OpenMV.
I want to connect multi mlx90614 temperature sensors to OpeMV and I met some problem when I assigned unique address to them. I write a script in python below. Erase the address by setting them zeros (according to EEPROM memory address in datasheet, I attach it in attachments) and then write new address to them.
from pyb import I2C
i2c=I2C(2,I2C.MASTER,baudrate=100000)
#ir_1=MLX90614(i2c, addr=0x5A)
def changeDirec (OldDirec, NewDirec):
    #print(i2c.mem_write( 0x2E ,OldDirec, 0X0E))                # send command for device to return address
    print('before:', i2c.mem_read(10, 0x5A, 0x0E, timeout  = 20000))
    i2c.mem_write( 0x00 ,OldDirec, 0x0E ,timeout  =20000)                  # send zeros to erase
    i2c.mem_write(0x5B, OldDirec, 0x0E, timeout  =20000)
    print('after:', i2c.mem_read(10, 0x5A, 0x0E, timeout  = 20000))
    #print('ok')
changeDirec ( 0x5A , 0x5B )        #Change the address to the new value
and I have found some code for Arduino and I really want to try to rewrite them in python.https://ofimatica-programacion.blogspot ... 90614.html
Have you met situations like this? How would you change i2c address?
MLX90614.rar
(1.07 MiB) Downloaded 9 times
Re: how to change i2c device address (Multi mlx90614 sensors)
Postby kwagyeman » Tue Jan 22, 2019 12:07 pm
Um, what's the issue you are having? If the camera does the I2C action to change the address... then you are find right?
Users browsing this forum: Bing [Bot] and 5 guests
