Is midpoint pooling median pooling, and why no max pooling?
kwiley
Postby kwiley » Sat Jan 19, 2019 3:26 am
Does midpoint pooling simply imply median pooling? If not, what exactly does it do?
Also, may I request (with low priority) max pooling as opposed to mean pooling. Max pooling is a staple of computer vision algorithms. Just throw it waaaaay back in your to-do list. I would never intend such requests to create any pressure on you.
Cheers!
Re: Is midpoint pooling median pooling, and why no max pooling?
Postby kwagyeman » Sat Jan 19, 2019 12:00 pm
Midpoint pooling actually does max pooling. Please note that versus creating a lot of algorithms for common use I made standard algorithms have more features through their arguments. See the bias argument of midpoint pooling. You can change it to either do max/min pooling by adjusting the bias argument.
Mean pooling is just the average. Midping is the max - min over 2. When you change the bias it becomes either all max or all min.
kwiley
Postby kwiley » Sat Jan 19, 2019 12:17 pm
That's more than sufficient. No need to add a function if parameters to an existing function serve the purpose. I just overlooked the feature. Thanks.
Postby kwagyeman » Sat Jan 19, 2019 12:45 pm
Like if you want adaptive thresholding the mean/median/mode/midpoint kernel filters all support this along with a few other methods.
Because memory is limited and I have to avoid copying you'll find I combined a lot of algorithms into one.
