Communication between OpenMV and ROS
ford_prefect
Postby ford_prefect » Sun Jan 06, 2019 12:44 pm
Hi there!
I'm fairly new to using the OpenMV cam (just starting), and I'd like to use it as part of a project which I will be working on.
In my desired setup for the project, I have an OpenMV cam and another MCU (still not quite certain which one), which will be running ROS.
My question is, is there a way to achieve communication between the OpenMV cam and ROS? Has it been done before, and if so, is there a guide/tutorial on how to do it?
I am not trying to actually run ROS on the cam itself. All computation will be done on the cam (as per usual), and the results will be forwarded to the other unit running ROS.
Re: Communication between OpenMV and ROS
Postby kwagyeman » Sun Jan 06, 2019 3:58 pm
Hi, you'd need to write a ROS node that receives serial data from a serial port and publishes the messages in ROS. In python code this isn't really a lot of lines.
Keep in mind the OpenMV Cam isn't a fixed function sensor where there's an obvious way to do this. You can design whatever application you want on the camera that sends serial data to a ROS node.
fabianschilling
Postby fabianschilling » Fri Jan 11, 2019 11:11 am
Hi, you may be interested in my https://github.com/fabianschilling/openmv_cam ROS package. I happen to have the exact same use case so I wrote a very minimal package that provides a OpenMV -> ROS interface.
Postby kwagyeman » Fri Jan 11, 2019 12:03 pm
Would you like this to be distributed with OpenMV IDE? It will get more usage then.
