How can I find minimum area rectangle in binary image?
pencilpen
Postby pencilpen » Fri Dec 07, 2018 11:02 pm
I have EmguCV project to find all minimum area rectangle in contour like below.
VB.NET with EmguCV code :
imgRects.Draw(CvInvoke.MinAreaRect(contour), New Bgr(Color.Red), 3)
How can I find minimum area rectangle in binary image like vb.net code as above?
Re: How can I find minimum area rectangle in binary image?
Postby kwagyeman » Sat Dec 08, 2018 12:18 am
Hi, please clarify how this relates to the OpenMV Cam?
We don't have a min area rect method. However, if you care about rotation the find_blobs() method returns the rotation angle of the object. Otherwise what is your goal with the min area rect?
pencilpen
Postby pencilpen » Sat Dec 08, 2018 12:50 am
Thank you for you fast reply. In my previous project, I use visual studio with emgu cv to measures width and length of object. In last project, I use openmv with non-distortion lens. Then I want to make embeded machine to use mesure width and length of object and have light display when found defect.
So I want to measure minimum area rectangle. That in my previous project, I use function as below.
CvInvoke.CvtColor(imgROI, imgHSV, ColorConversion.Bgr2Hsv)
CvInvoke.InRange
CvInvoke.FindContours(...............................
Please suggess me.
Postby kwagyeman » Sat Dec 08, 2018 11:23 pm
I understand what you need to do. Um, so the rect we return has a left/right/up/down parts. However, this ins't the min area rect... but, the min area rect intersects these points.
Anyway, the easiest way to get this is to take the rotation angle from the find_blobs() function and rotate the rectangle corners by a 2D rotation matrix.
E.g.
For each point of the of the rect do trate the point as:
[X
Y]
and the mulitply by: https://en.wikipedia.org/wiki/Rotation_matrix where pheta is the rotation angle from find_blobs().
I understand you'd prefer some working code versus how to do it but I am answering this from not at home right now and I'm unable to write some code for this. However, we can add this feature to the firmware. Please submit a github ticket issue for it.
pencilpen
Postby pencilpen » Mon Dec 31, 2018 3:34 am
I found new update OPENMV ide with new firmware. Do you add minimum area rectangle in last firmware?
E.g.
[X
Y]
Postby kwagyeman » Mon Dec 31, 2018 12:11 pm
Not yet. I've finally completed enough tasks to get back to doing firmware updates however. So, the next firmware release should have this feature.
Um, note, I plan to just expose the four extreme corners of the object. The minimum rect will just then be parallel lines that pass through these corners.
In our lib a rect() is never rotated... So, to draw the minimum rect you'd have to call draw line repeatedly on each corner to corner. Anyway, do you actually need the minimum rect or just the extreme corners?
pencilpen
Postby pencilpen » Tue Jan 01, 2019 12:00 am
I want bounding rotated rectangle that can returns center, angle, width, height, point[0], point[1], point[2], point[3] and contour area as attach picture. Thank you and Happy new year.
http://www.emgu.com/wiki/index.php/Mini ... _in_CSharp
https://docs.opencv.org/3.2.0/dd/d49/tu ... tures.html
Postby kwagyeman » Tue Jan 01, 2019 3:40 am
Yeah, I get what you want to do. But, keep in mind you haven't presented a use case other than you want to display this onscreen which is a rather weak need for it. We have a method that gives you already the rotation an object.
Anyway, given what you want. I'll add the outer edges of the object points along with projected points that show the min bounding rect.
Note that I will note be adding the contour value. I mad a decision a while back not to add that explicitly because of the limited RAM on the system. To keep an object contour requires retaining a variable length list of points of the object which takes quite a bit of ram and is not suitable for an embedded system. I understand this prevents using a lot of different features OpenCV has for object introspection but this is okay.
Anyway, I'm coding right now and fixing other bugs but will start on this feature on Wednesday. I should have it done before the end of the week and I'll share a new binary with you for it.
Postby kwagyeman » Mon Jan 07, 2019 4:11 am
Hi, okay, I did it. Attached is the new firmware. Here's some sample code:
# Single Color RGB565 Blob Tracking Example
# This example shows off single color RGB565 tracking using the OpenMV Cam.
threshold_index = 0 # 0 for red, 1 for green, 2 for blue
# Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max)
# The below thresholds track in general red/green/blue things. You may wish to tune them...
thresholds = [(30, 100, 15, 127, 15, 127), # generic_red_thresholds
              (30, 100, -64, -8, -32, 32), # generic_green_thresholds
              (0, 30, 0, 64, -128, 0)] # generic_blue_thresholds
# Only blobs that with more pixels than "pixel_threshold" and more area than "area_threshold" are
# returned by "find_blobs" below. Change "pixels_threshold" and "area_threshold" if you change the
# camera resolution. "merge=True" merges all overlapping blobs in the image.
    for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold=200, area_threshold=200):
        img.draw_line(blob.corners()[0][0], blob.corners()[0][1], blob.corners()[1][0], blob.corners()[1][1], color=(0,255,0))
        img.draw_line(blob.corners()[1][0], blob.corners()[1][1], blob.corners()[2][0], blob.corners()[2][1], color=(0,255,0))
        img.draw_line(blob.corners()[2][0], blob.corners()[2][1], blob.corners()[3][0], blob.corners()[3][1], color=(0,255,0))
        img.draw_line(blob.corners()[3][0], blob.corners()[3][1], blob.corners()[0][0], blob.corners()[0][1], color=(0,255,0))
        img.draw_line(blob.min_corners()[0][0], blob.min_corners()[0][1], blob.min_corners()[1][0], blob.min_corners()[1][1], color=(0,0,255))
        img.draw_line(blob.min_corners()[1][0], blob.min_corners()[1][1], blob.min_corners()[2][0], blob.min_corners()[2][1], color=(0,0,255))
        img.draw_line(blob.min_corners()[2][0], blob.min_corners()[2][1], blob.min_corners()[3][0], blob.min_corners()[3][1], color=(0,0,255))
        img.draw_line(blob.min_corners()[3][0], blob.min_corners()[3][1], blob.min_corners()[0][0], blob.min_corners()[0][1], color=(0,0,255))
Drawing the lines is kinda a pain right now. I'll add two more draw methods to make this easier.
So, the corners value is the object corners. It's always sorted from the left, top, right, and bottom. Min corners is then the min area rect. I was going to call it min_area_rect_corners() but that was too verbose.
Note that since the min area rect is generated by just a few points it's quite jumpy. Set your thresholds well.
firmware.zip
(918.48 KiB) Downloaded 41 times
pencilpen
Postby pencilpen » Thu Jan 10, 2019 3:39 am
Thank you friend about blob.min_corners(). I will try to use.
About my project, I have egg place on green black ground. First step, I will detect green color in Lab color space and invert. So I will reach egg area. Then I want use to know ratio between width and length of egg area.
I not sure that the egg put align with camera sensor. So I want to use minimum rectangle area enclosing egg area. After than I will sent width and length data to process through UART to Arduino.
Please suggest me. What OpenMV library do I need?
Postby kwagyeman » Thu Jan 10, 2019 12:01 pm
Hi, I recently updated the firmware method with a major_axis_line() method that will tell you the longest length of the side in the min_area_rect. So, that's basically what you need.
As for transmit via the UART. See the UART example on our docs. You can just print the value.
I'll upload the new firmware tonight.
Postby kwagyeman » Mon Jan 14, 2019 2:43 am
Hi, I'm still working on the min_area_rect() method. The method I used doesn't seem to work in all situations. It's very memory intensive to store the contour and then calculate the min_area_rect() per frame based on a full contour of the object. I am trying to figure out a way to do this with just 4 points but I have not found anything really robust yet...
In the mean-time I've upgraded the find_blob() method to be measurably faster, better merging, added perimeter support, floating point centroid, roundness calculation (eccentricity), and x/y histogram projections.
I will continue working on this until I can find a solution. Since I added the perimeter code I know what pixels are on the perimeter of the object so I could allocate a point list which will work on the F7/H7s RAM. However, I want to get this working on the M4 which requires me to do this in the least memory usage way possible.
EDIT: An idea... I think if I combine the 4 corners with the 4 diagonal corners I will get a much better result. I will see what I can do with a constrained list of points based on local optima of geometric identities.
Note: On the H7 I'm getting 80 FPS at 320x240 and 30 FPS on VGA grayscale. The code is fast.
pso
Postby pso » Mon Jan 14, 2019 7:08 am
I would like to use this function with sensor.set_pixformat(sensor.GRAYSCALE)
Have you a solution ?
thank you
pso
Postby pso » Mon Jan 14, 2019 8:11 am
At the 1st draw.line, I can see this error message :
attribute errors : 'blob' object has no attribute 'corners'
Postby kwagyeman » Mon Jan 14, 2019 12:35 pm
Hi, you have to update the firmware on your camera using the firmware binary I posted above.
Yes, it works on grayscale.
The current algorithm is not as robust as it needs to be. I will post another version that should work better tonight.
pso
Postby pso » Tue Jan 15, 2019 2:55 am
Yes it seems to be the last firmware : 3.2.0.
Postby kwagyeman » Tue Jan 15, 2019 11:55 pm
No, you have to download the firmware above. I posted a binary file a few posts back. This is a firmware cut that's a pre-release.
Anyway, I'll post something else again.
